wireless ignition node LOCKOUT! HELPPP! - JeepForum.com
post #1 of 4 Old 11-10-2008, 07:28 PM Thread Starter
yochay101
2008 XJ Cherokee
Hello everyone,
My jeep (GC 2008) came with only one key (fob).
After i get a new key i went to the dealer to program it - here is the problem:
for programming the new key using the scan-tool we need the PIN number
(like 1234), so the dealer used the wrong PIN number for 3 times (using the
scan-tool) and then we get this message on the scan-tool: "the WIN has
exceeded the total number of false PIN attempts and has entered the anti
scan lockout mode", so now its locked and we cannot enter the correct PIN
because of it!
Does someone know how to reset this anti scan mode (cancel it) ???
yochay101 is offline
post #2 of 4 Old 11-11-2008, 06:12 AM
MacCherokee
2008 WK
How should this be your problem? You went to the dealer and this is now their problem. If they can't figure this out quickly, they should provide you with a loaner until they do.
It must be frustrating but they should have the resources to solve this problem.
Good luck.
08 GC CRD Limited
06 Volvo V50 T5 AWD
Your direct access to Canada/US Dealer-only Auctions
MacCherokee is offline
post #3 of 4 Old 11-11-2008, 06:21 AM
merlinTec
merlinTec's Avatar
Hi
You will probably need a new WIN module but like above not your problem.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #4 of 4 Old 11-14-2008, 06:00 PM
TheTrot
You can do one of two things.
1. Leave your ignition key in run for one hour, this resets the lockout counter.
2. Find the memory address and someone who has a Chrysler Diagnostic Tool engineering version (CDAe) and have them overwrite the lockout counter.
People with CDAe can also read the PIN out by knowing the memory address. This only works on Continental/Siemens VDO WINs which the 2008+ WK/XK's use.
TheTrot is offline
engine lockout 94 zj? SpoonyGSR ZJ Grand Cherokee Forum 2 11-08-2009 10:22 AM
Hey For You Axle And Gear Junkies...HELPPP! ZJForBreakfast ZJ Grand Cherokee Forum 19 01-18-2008 12:02 PM
Hvac Removal Helppp!! 99 Wj GRDCHRKE555 WJ Grand Cherokee Forum 21 08-02-2007 12:28 PM
ZJ front CV driveshaft helppp apex96zj ZJ Grand Cherokee Forum 9 05-18-2007 10:06 PM
HELPPP !!! windows not going down meowmixxer ZJ Grand Cherokee Forum 4 07-24-2005 01:39 AM
