windsheild washer pump location? - JeepForum.com
post #1 of 3 Old 12-09-2007, 03:48 PM Thread Starter
Y-Factor
2006 XK Commander
My Commanders washer pump went out. Does anyone know where its located, and if its easy to replace?
Y-Factor is offline
post #2 of 3 Old 12-09-2007, 05:26 PM
TRZ
2008 WK
Assuming it's in the same location as the WK, it's behind the front fender on the driver's side, attached to the outside of the subframe (so it's next to the tire). It's either inside the washer reservoir or (more likely) attached directly to it. If that is the location, the easiest way to replace would probably be to remove the (driver's side) front tire.
TRZ is offline
post #3 of 3 Old 12-10-2007, 09:05 AM Thread Starter
Y-Factor
2006 XK Commander
washer pump
Thanks, I'll check it out and post my findings.
Y-Factor is offline
Problem with washer pump on 99 WJ PitBull4X4 WJ Grand Cherokee Forum 2 04-04-2010 08:06 PM
WJ rear washer fluid pump location the88thpianoman ZJ Grand Cherokee Forum 6 08-28-2009 07:06 PM
WJ Windsheild Washer Bottle BlackSS ZJ Grand Cherokee Forum 6 08-06-2009 09:26 PM
Strange Washer Pump Problem casperboy77 ZJ Grand Cherokee Forum 2 11-19-2008 10:28 PM
windsheild washer not working pfckopp88 ZJ Grand Cherokee Forum 12 12-25-2004 02:36 PM
