window problem - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > window problem
Steering and more from Ruffstuff!The Ruffstuff 14 Bolt Complete Swap Kit!Ruffstuff Axle Simple Swap Kit!
Unread 02-14-2007, 12:24 PM   #1
beckysjeep
window problem
My windows were froze shut. Today I got my drivers side open, now it won't go back up. Any suggestions will be welcome.
beckysjeep is offline   Reply With Quote
Unread 02-14-2007, 12:26 PM   #2
Harts2k
Can you hear the motor trying to bring the windows up or is there ice covering the opening?
Harts2k is offline   Reply With Quote
Unread 02-14-2007, 12:50 PM   #3
beckysjeep
yes when you push it to go down. no to go up and sounds like its crunching in there.
Unread 02-14-2007, 12:51 PM   #4
beckysjeep
It's only down about 2 - 3 inches...good thing, I have a 27 mile drive home and it's 19 degrees.
Unread 02-14-2007, 01:05 PM   #5
OnlyInARealJeep
OnlyInARealJeep's Avatar
I'd say its from it being so cold. Let the temperature warm up a little and see what happens.
Current: 2006 Midnight Blue Jeep Grand Cherokee WK Limited 4.7L V8
Modifications: Magnaflow Exhaust System, K&N 63 Series Intake System, JET Chip Stage Two, Addco Anti-Sway Bars, 4xGuard Front Guard II, 4xGuard Side Steps With Rock Rails, 4xGuard Rear Guard HC, Mopar Front Suspension Skid Plate, Door Entry Guards, Mopar Tail Light Guards, SRT-8 Sports Pedals, Commander Shifter Knob, Two 10" JL Audio W6v2 Subwoofers, JL Audio 500/1 Amp, And Thule Sport Utility Bars With Six Skis or Four Snowboards Clamps And Fairing.
Up Next: Front Window Tint and 4xGuard Belly Guard HC
OnlyInARealJeep is offline   Reply With Quote
Unread 02-14-2007, 01:16 PM   #6
beckysjeep
Do you really think so? That would be wonderful if that's all it is!
Unread 02-14-2007, 01:24 PM   #7
Harts2k
I agree. Sounds like it is too cold.
Unread 02-14-2007, 01:57 PM   #8
beckysjeep
One of my co-workers just went out with me and I pushed the button for the window to go up, which you can hear the motor but it doesn't do anything and he pulled it up so we could close it. Now it won't go down either. Guess it's better up than down.
Unread 02-14-2007, 06:44 PM   #9
OnlyInARealJeep
Yeah I don't know what to tell you now. You might of screwed it up actually messing around with it out in the cold, but who knows. Just wait until it gets a little warmer to go messing with it again.
Unread 02-16-2007, 03:18 PM   #10
beckysjeep
while I'm here....can someone explain the difference between WJ and the other initials applied to jeeps?
Unread 02-16-2007, 03:48 PM   #11
Harts2k
The intials indicate a certain body type of jeep or model year. WK is from 2005 to 2008. XK is the Commander and so on and so forth. Is that the question you had or are you asking how they got those labels?
Unread 02-26-2007, 01:15 PM   #12
beckysjeep
My son-in-law took my door apart. There was a chunk of plastic that appears to have broken off laying in the bottom of the door. It is sort of a half circle and looks like it was some kind of guide maybe? Any clue?
Unread 11-20-2011, 04:35 PM   #13
mwalters2
2005 WK
I'm thinking that I have a similar problem. Windows were stuck by frost, so I used the power to go up and down until they broke free. Worked on the driver's side front, but not the driver's side rear. The motor makes a strange noise now, and won't move the window more than 1/2" (it's warm now, so it's not the temp). I think I probably burned up the motor. Have to pull the door panel and take a look at it.
2005 Jeep Grand Cherokee Larado 4.7L
mwalters2 is offline   Reply With Quote
Unread 11-20-2011, 06:51 PM   #14
tdoster
2007 WK
If you hear the motor and the window does not go up and down, it is off the tracks or the rollers are busted off.
The round thing you found on the bottom of the door is probably the roller.
Easiest way to describe how these work is think of a sissor jack that you jack you car up with. Put a roller on the top and place it on a track. When the sissor jack goes up, the roller moves down the track while raising the track up. Sometimes with a lot of wear, the roller will start to pop off the track, other times when forced with a good motor and too high a fuse (like a frozen wet window), the entire roller will break off.
Many cases the whole mechinasim must be replaced because the rollers are rivited on, but a home fix on some is to drill out the rivit and use a shower or screen door roller from the hardware store, which does not require taking the whole mechanism out.
I have replaced a couple of them in my lifetime, and the home fix is much more attractive than taking the whole thing out and replacing the sissor arms.
There is a temp fix to keep the window up. Push down on the switch until the motor stops then open the door and using both hands pull the window up by hand. Then roll the window all the way up with the switch. What usually happens is the sissors raise and lock the window up. BEWARE that the window can get knocked and fall down, so it is a temporary fix until you can get it fixed.
It can be an expensive and cold lessen to not roll your windows up and down until the car has warmed up and you used your ice scraper to clear them off. They are not made to clear ice and snow and will wear quickly or just plain break.
tdoster is offline   Reply With Quote
Unread 11-25-2011, 10:54 AM   #15
mwalters2
2005 WK
Well, I had a chance to pull off the door panel today, and I think I found the problem:
Cable broken - looks like I need to replace the window regulator!
