Window auto up problem - JeepForum.com
post #1 of 7 Old 12-30-2015, 02:59 PM Thread Starter
JackB1
2008 WK
2008 WK suddenly decided that my auto up feature for side front windows would go on the fritz. I thought it might reboot after turning engine off and back on but no luck. I do understand that it has a second click on the button that activates the feature. Just not working. Any suggestions on trouble shooting this problem?
JackB1 is offline
post #2 of 7 Old 12-30-2015, 03:22 PM
ruggedscotsman
2007 WK
Might just need to reset the auto feature.
Involves cycling the window up and down and holding the switch.
http://www.**********.org/f187/how-t...dow-10297.html
See the three part instructions half way down the page...worked for me.
ruggedscotsman is offline
post #3 of 7 Old 12-30-2015, 07:08 PM
Tango.
2008 WK
Does this happen with just the driver control, or also with the passenger control? If the passenger control works could be the driver switch.
Life is hard-John Wayne
Tango. is offline
post #4 of 7 Old 12-31-2015, 12:57 PM Thread Starter
JackB1
2008 WK
Thanks for the fix. It worked. Reset both windows from drivers side. Took a while as I found out that by holding window button up too long actually disables the window. You can hear a quiet click when holding the button up and right after that is the time to let button go. Thanks again.
JackB1 is offline
post #5 of 7 Old 12-31-2015, 01:49 PM
jeepinmoe
2008 WK
Link won't work
An armed society is a polite society. Stand your ground.
jeepinmoe is offline
post #6 of 7 Old 12-31-2015, 04:35 PM
Nejeep
Here is an older discussion with the reset procedure included.
http://www.jeepforum.com/forum/f67/s...oblem-1205109/
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #7 of 7 Old 01-01-2016, 07:20 AM
ruggedscotsman
2007 WK
Originally Posted by jeepinmoe View Post
Link won't work
Not sure how to link other sites without this happening... Google wk auto window reset and you should come across a number of forum threads on the topic.
