Will these Rubicon wheels fit my 05 WK? - JeepForum.com
post #1 of 9 Old 08-13-2013, 06:04 PM Thread Starter
cjjon7
1983 CJ7
Yes, i know its been covered on earlier model jk's, but will the new 2014 rubicon 17x7.5's fit on an 05 WK as well with slight spacers? Heres a pic of the wheels...
cjjon7 is offline
post #2 of 9 Old 08-13-2013, 06:22 PM
Anon155
2005 WK
Check out the wheel and tire thread. There was a guy who put a set of these on just recently. I believe he had a 1.5" spacer though. I bet they would have the same problem as the moabs with the front caliper rubbing. I have 2012-13 moabs on my Jeep. I doubt the JK would have changed hub assemblies going into 2014.
05 Jeep Grand Cherokee: ORT 4X4; Khaki #55
Too many mod's to list...
Anon155 is offline
post #3 of 9 Old 08-13-2013, 06:30 PM Thread Starter
cjjon7
1983 CJ7
Yeah theyre a 5 on 5 pattern, backspacing is all im worried about. Eek, 1.5 spacer is pretty large....
cjjon7 is offline
post #4 of 9 Old 08-13-2013, 06:32 PM
wstacy3
you will need a 1.5 spacer like the spidertrax or rough country
wstacy3 is offline
post #5 of 9 Old 08-13-2013, 06:55 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
^^^ Agreed.
The JK wheels in the OP have the same backspacing as factory WK wheels: 6.25"
Assuming all other things being equal, spacers will be in order to avoid rubbing.
BTW - OP, 1.5" spacers are very common. Nothing to be afraid of or shy away from.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #6 of 9 Old 08-13-2013, 08:18 PM Thread Starter
cjjon7
1983 CJ7
I was hoping the 1/4 spacers would work as with the moabs ..
These are new take offs with 200 miles on them, 1000$ is a pretty fair price I guess!
cjjon7 is offline
post #7 of 9 Old 08-13-2013, 08:43 PM
Anon155
2005 WK
You prob could run the 1/4" spacer up front if you wanted to. You don't have to go as big as the 1.5". That's just what a lot of people go with since it's a trusted brand. IMO, it looks a bit goofy to have that big of a tire stuffed all the way inside the wheel wells. I like the look of the tires slightly sticking out. Gives it more of an aggressive stance, also widening the stance to make it more stable on road and off.
Anon155 is offline
post #8 of 9 Old 08-14-2013, 09:26 PM Thread Starter
cjjon7
1983 CJ7
Doesn't it start to track goofy with the tires out like that?
cjjon7 is offline
post #9 of 9 Old 08-14-2013, 09:33 PM
Anon155
2005 WK
The tires only would stick out 1/2"....That's not a lot. There are some who use a 1" spacer that would be even with the fender wells. On road and on the trail I've never had problems tracking up a hill or finding my lines.
Anon155 is offline
