Will a bad brake light cause a code? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Will a bad brake light cause a code?
Black Friday Sale - Deep Discounts from ExtremeTerrain.com6th Annual, Beat Your Wife to the Credit Card Sale!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome Effect
Unread 11-20-2014, 12:13 PM   #1
Wrangler98
I'm working on my friends 2005 JGC with the 5.7. She has the service brake electrical system error. She took it so a shop and was told a new brake switch and a new third brake light assembly would clear it. I offered to do it to save her a few hundred dollars. I ordered a new brake switch which was only $8, but I also noticed some exposed wiring going to the switch which I will deal with as well. I have also ordered a new brake light assembly($80 ouch). The way the shop described it was that the light alone could cause the code if not replaced as well. Is this true, the way electrical items are entangled these days, I could see it happening. I also don't trust this shop, my friend forgot it was the same shop that tried to con her daughter into getting $1200 worth of front end work that I had just completed.
2012 Jeep Wrangler Sahara-3.6/AT
1993 F-250HD SC 4X4-7.3/5spd ATS Turbo
1986 F-250HD 4X4-6.9/T19
1967 Ford Mustang-351W/4spd
Wrangler98 is offline   Reply With Quote Quick reply to this message
Unread 11-20-2014, 02:03 PM   #2
luckyse7ens
2010 XK Commander
This thread appears to address the same issue. Wheel speed sensor and/or brake light switch is the culprit for several Jeepers there.
http://www.jeepforum.com/forum/f67/s...77/index2.html
Black WK Club #152
luckyse7ens is offline   Reply With Quote Quick reply to this message
Unread 11-20-2014, 10:00 PM   #3
Wrangler98
I read up on a bunch of that when I was searching, didn't see anything about the brake light though. I was just curious is all and trying to save my friend a few bucks since her husband just got laid off and has to take the jeep out of state for a new job. She opted to change everything anyway, better safe than sorry.
Unread 11-21-2014, 05:30 PM   #4
luckyse7ens
2010 XK Commander
Sorry I couldn't help any more
Glad to hear they are back Jeepin'
Black WK Club #152
Unread 11-21-2014, 06:17 PM   #5
unobtanium
2010 WK
On some Ford trucks, it will prevent it from going anywhere, I believe.
No repairs in 30 days and counting! Nirvana!
*Scratch that, 7/30, HEEP broke again. Fail.
unobtanium is offline   Reply With Quote Quick reply to this message
Unread 11-21-2014, 06:55 PM   #6
bustacrab
2005 WK
I had the same exact issue with mine. One of the circuits in the brake switch was shorted and the cruise wouldn't work. I kept getting the Service Elect. Brake System warning. I finally got a CEL and ran the code, it was something like Brake Circuit 1 shorted.
At any rate, I changed the switch under the pedal and fixed the problem.
bustacrab is offline   Reply With Quote Quick reply to this message
Unread 11-21-2014, 10:35 PM   #7
joe989
2008 WK
Most modern vehicles have whats called a SAM (signal actuation and control module), which will throw a trouble code to let you know a light, or electrical fault has occurred.
joe989 is offline   Reply With Quote Quick reply to this message
