why are my brakes still locking up on me..... - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > why are my brakes still locking up on me.....
The Cure for your Tie Rod Roll!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-26-2015, 10:27 AM   #1
KillaJeep4569
2006 WK
hey guys what's up. so I replaced the rotors n pads all around truck. and the front brakes still lock up on me on wet roads or in the snow. I thought these trucks had abs? and locking should not happen as it is with me.
any suggestions? I have no lights or codes. so I'm trying to wonder what it is.
should one bleed the brakes after replacing the rotor and pads??
KillaJeep4569 is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 10:45 AM   #2
KonLegend
2005 WK
Sounds like your abs isn't working properly, do you have any lights on your dash? Did you unplug an abs sensor?
2005 WK 5.7 Hemi Limited
Superchip Performance Tune
K&N Intake
Flowmaster Super 40 w/reso delete
KonLegend is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 10:47 AM   #3
KonLegend
2005 WK
Brakes don't need to be bled when only replacing rotors and pads. The only suggestion is to take your brake reservoir cap off when you are pressing the calipers back to make room for new pads, the fluid needs somewhere to go.
K&N Intake
Unread 03-26-2015, 10:47 AM   #4
KillaJeep4569
2006 WK
Originally Posted by KonLegend View Post
Sounds like your and isn't working properly, do you have any lights on your dash? Did you unplug an abs sensor?
no lights on. no codes either. I didn't unplug anything. and yes it does sound like it isn't working right. what can I do to check this
Unread 03-26-2015, 11:46 AM   #5
KonLegend
2005 WK
Gonna have to set the whole thing on fire probably
K&N Intake
Unread 03-26-2015, 11:53 AM   #6
KillaJeep4569
2006 WK
your funny ha ha
Unread 03-26-2015, 12:48 PM   #7
90grandoneer
2006 WK
Any local shop with a good computerized diagnostic tool should be able to check the entire ABS system. I know my Autel DS708 can do it. Or, you could go to a stealer and probably risk a good chance of getting ripped off.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline   Reply With Quote Quick reply to this message
Unread 03-26-2015, 01:01 PM   #8
monkey6
2009 WK
haha Well his name is KillaJeep
2009 WK 3.7. 2" RC, 1.5" spacers, 265/70/17 BFG KM2's
monkey6 is offline   Reply With Quote Quick reply to this message
Unread 03-28-2015, 10:02 AM   #9
KillaJeep4569
2006 WK
Think i may take it to my local shop and see what the mechanic says. I wonder how much they would charge me to connect the computer tool and diagnose. I dont see lights or any codes on dash. So Im just wondering why they would lock up. I always thought that is what ABS was for, not to lock up and pulsesate the brakes for you.
Unread 04-03-2015, 08:17 PM   #10
90grandoneer
2006 WK
Obviously the ABS should be stopping the brakes from locking up. If the ABS is working, when doing a hard stop (or on slippery roads) you'll feel a little pulsating in the brake pedal and you should also be seeing the ABS light on the dash flickering or lighting up. Let us know what you find out.
Unread 04-03-2015, 10:08 PM   #11
TurboDiesel
2008 WK
is your cruise control working?
sometimes when people are having ABS [wheel speed sensor] issues their cruise control doesnt work
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is online now   Reply With Quote Quick reply to this message
Unread 04-03-2015, 10:17 PM   #12
TangoTango
2008 WK
air in the lines will do that.. bled them
Black WK Club #147
Life is hard. ...- John Wayne
TangoTango is offline   Reply With Quote Quick reply to this message
Unread 04-04-2015, 09:03 PM   #13
KillaJeep4569
2006 WK
i dont see any lights coming on when I am locking up or the sort.
Unread 04-04-2015, 09:03 PM   #14
KillaJeep4569
2006 WK
Yes cruise control works fine.
Unread 04-04-2015, 09:04 PM   #15
KillaJeep4569
2006 WK
Yeah that is what I was thinking, but It doesnt feel sloppy or loose when I am hitting the brakes.
I just did a complete brake tune up new rotors and pads all around. So I was thinking to bleed them, but some said it was not needed
