Why does my alarm go off when I unlock the door with my key? - Page 2 - JeepForum.com
post #16 of 26 Old 05-12-2013, 06:00 PM
Chirpz
Chirpz's Avatar
2007 WK
Originally Posted by ColinWK View Post
Either something is messed up or Chrysler didn't use their brain when they put this feature in...
If I unlock the door manually with my key, which I had to yesterday before I could get another battery for the remote unlock, the alarm goes off if I open the door.
Does this happen for anyone else and is there a way to put a stop to that?
Hee Haw!! Hee Haw!!
Mine does it too.... always has.
I discovered it at a quiet forest camp ground about 11:30 PM after everyone was asleep. I needed some meds out of the Jeep and I knew my headlights were pointed directly into someone's tent one site over. I knew if I pushed the fob, It would flash my headlights right into their tent so I decided to quietly sneak out and use the key manually in the door. So I'm standing there in my jammies being extra quiet and smug patting myself on the back for thinking ahead and being considerate and then I turned the key....
Honk Honk Honk Honk....flash flash flash. I panic not knowing what to do....so I push the panic button thinking it would shut the (*$#@% thing off..... WRONG.... it goes into double time. Double honk, double flash, double honk honk honk honk!!!!!
Long seconds pass, lights begin to come on around the camp ground. Voices and curses can be heard along with some jeers and laughter (not much laughter.) I finally jump in and crank the Jeep and the sound goes away. Whew!
Next day, I felt STUPID as I slinked around the camp ground hoping nobody would remember.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #17 of 26 Old 05-12-2013, 06:05 PM Thread Starter
ColinWK
2005 WK
Originally Posted by Chirpz View Post
Hee Haw!! Hee Haw!!
Oh god that is awful. This is basically my morning routine whenever the remote decides not to work. I always have to position myself to jump in and turn on the car immediately to turn it off. I hate it so much and am looking for a way to fix it.
ColinWK is offline
post #18 of 26 Old 05-12-2013, 08:15 PM
Shafer57
2006 WK
Confirm that the cradle holding the battery is soldered down at all three points.
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline
post #19 of 26 Old 05-12-2013, 08:28 PM
GPERSCREEPERS99
GPERSCREEPERS99's Avatar
I just replaced the battery for the remote and it only works about half of the time. Wondering if it's a faulty battery or they messed up my key
I have the exact same issue with one of my keys. I think I need to get a new key.
99 Jeep Wrangler built on 35's
82 Aqualu Aluminum Scrambler Chevy 350 on 33's
14 JKU Rubicon My Daily Driver
12 Grand Cherokee Wife's Daily Driver
GPERSCREEPERS99 is offline
post #20 of 26 Old 05-12-2013, 10:25 PM
cherrybomb05
2010 JK Wrangler
You didn't turn the key far enough in the door. It takes some force. Make sure the thing inside your door is all the way up before opening.
07 WK
10 JKUR
11 JKR
cherrybomb05 is offline
post #21 of 26 Old 05-13-2013, 02:18 PM
marko138
2011 WK
Mine does the same thing. Extremely annoying.
marko138 is offline
post #22 of 26 Old 05-13-2013, 05:19 PM
yzjwk
2005 WK
If you guys don't want the expense and hassle of buying a new key fob and dealer programming cause you don't have 2 keys etc . for a couple hundred bucks you can get a command start module installed and just use the key fob that comes with that to lock and unlock .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #23 of 26 Old 05-13-2013, 05:58 PM
Jaashua
2005 WK
For a couple hundred bucks you can get a dealer key...
Jaashua is offline
post #24 of 26 Old 05-13-2013, 06:14 PM
yzjwk
2005 WK
True , but you wouldn't have command start and you would still have another fragile key fob to break on you . The starter fobs are way more resiliant and you can get ones that will take a AAA batery .
90 YJ Islander 4.2L
2010 MK Patriot
yzjwk is offline
post #25 of 26 Old 06-22-2013, 07:36 PM
wkearney99
2006 WK
It's pretty trivial to just resolder the battery holder clip inside the remote. That's what was causing mine to act up. But after 6 years of being knocked around it's surprising there wasn't more wrong... or that the battery lasted that long!
wkearney99 is offline
post #26 of 26 Old 10-22-2013, 02:33 PM
GPERSCREEPERS99
I fixed mine by ordering two new keys on eBay and getting them cut. Grand total for two new keys and cut at local locksmith 60 bucks. Dealer wanted $410. Mine was loose clips on battery. I tried soldering but it didn't work for me. The new keys have a different design to hold the battery and it won't happen again.
