Why does my alarm go off when I unlock the door with my key? - JeepForum.com
post #1 of 26 Old 05-09-2013, 06:13 PM Thread Starter
ColinWK
2005 WK
Either something is messed up or Chrysler didn't use their brain when they put this feature in...
If I unlock the door manually with my key, which I had to yesterday before I could get another battery for the remote unlock, the alarm goes off if I open the door.
Does this happen for anyone else and is there a way to put a stop to that?
ColinWK is offline
post #2 of 26 Old 05-09-2013, 06:19 PM
Mainsail
2005 WK
Because the vehicle can't tell the difference between a key and a slim-jim. All it knows is that the door opened.
Poor grammar is something up with which I shall not put.
Mainsail is offline
post #3 of 26 Old 05-09-2013, 06:20 PM Thread Starter
ColinWK
2005 WK
Is there a way to disable it or something?
ColinWK is offline
post #4 of 26 Old 05-09-2013, 07:06 PM
Discman03
2008 WK
I had this issue when the fob stopped working and I was waiting for a new one. If you manually lock the doors instead of using the button, it won't set the alarm(because the alarm is not activated). Also, you could hop in and drive off. I believe the alarm shuts off once you're over 15mph.
Discman03 is offline
post #5 of 26 Old 05-09-2013, 08:41 PM
Shafer57
2006 WK
Haven't tested this yet, but on most cars/trucks, turning the key 2 to sometimes 8 times disarms the alarm. As well as unlocks all doors versus just the driver.
A Chrysler T&C I worked on was clockwise 8 times to disarm.
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline
post #6 of 26 Old 05-10-2013, 12:37 AM
trax95008
2006 XK Commander
I don't think that's true. When you unlock with a key, the sentry key system "looks" to see if its a programed key and disables the alarm. I think in this case, there is something wrong with he OP's vehicle. It should not behave that way
trax95008 is offline
post #7 of 26 Old 05-10-2013, 01:01 AM
TurboDiesel
2008 WK
the lock button on the fob arms the alarm
the unlock disarms the alarm...
simple
my alarm goes off when i use my key too
just stick the key in the ignition and turn it to the on position
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #8 of 26 Old 05-10-2013, 10:26 AM
IndyBlueWK
2005 WK
isnt this messed up.. My Bat has been dead in my keyfob for months and I deal with this crap everyday....
IndyBlueWK is offline
post #9 of 26 Old 05-10-2013, 06:15 PM
Shafer57
2006 WK
The range on a transponder for a key is about 1/2". There is no sensor in the door locks to look for a transponder (Sentry Key).
Shafer57 is offline
post #10 of 26 Old 05-10-2013, 06:16 PM
w1pf
Who, me?
w1pf's Avatar
2007 WK
hm, the battery is not all that expensive.. you could just replace it, unless you like complaining about it
But whatever.
2014 WK2 Overland 5.9L
2007 WK Limited 5.7L
And some past Durangos
Red WK #19, Hemi #68.. I think..
Durango Owners Club DOTY 2011
"Must have been that yesterday was the day that I was born"
w1pf is offline
post #11 of 26 Old 05-10-2013, 06:22 PM
skip11and1
2013 MK Patriot
may be something with the battery being dead too. Since there is a chip in the key the battery for the fob may have something to do with sending a signal to the key to turn the alarm off?...just a guess
2013 Jeep Patriot 4x4 FD1 5spd
2004 R6 lowered, stretched, full exhaust, HIDs etc
2004 TJ Columbia package long armed w/ 33's (Sold)
2005 WK, v6 QT1 (girlfriends)
skip11and1 is offline
post #12 of 26 Old 05-11-2013, 01:22 PM
terrasmak
2007 WK
That is lame, even my 98 Ford Explorer could tell when the key was used to unlock the door and wouldn't set the alarm off.
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #13 of 26 Old 05-11-2013, 02:21 PM
Shafer57
2006 WK
Same range. The only thing your explorer could tell is that the linkage was moved in the door by key, there are no "sensors" to see the chip in the key in any door locks.
My bet is that if you armed the vehicle with a remote, and left your window cracked. Reached inside the window and pulled the door handle from the inside it would go off.
Shafer57 is offline
post #14 of 26 Old 05-11-2013, 09:16 PM
YB Normyl
YB Normyl's Avatar
2016 JK Wrangler
The Intrepids, 300Ms, and Concordes equipped with alarm had a small Pezo switch that snapped on the back of the door lock cylinder
so when you turn the cylinder to lock or unlock, it would arm or disarm. Using a slimjim moves the rod but doesn't turn the lock cylinder.
i guess they did away with that system.
YB Normyl is offline
post #15 of 26 Old 05-12-2013, 02:02 PM Thread Starter
ColinWK
2005 WK
I just replaced the battery for the remote and it only works about half of the time. Wondering if it's a faulty battery or they messed up my key
ColinWK is offline
