Whistling noise from '08 Cherokee Laredo while accelerating and turning off. - JeepForum.com
post #1 of 5 Old 07-16-2009, 02:09 PM Thread Starter
dyne
I've had my '08 Cherokee Laredo (3.7 v6 ) for about 2 months now. Balance of 36/3 warrenty just expired and I have noticed a whistling noise coming from the engine. The noise sounds like a wooden train whistle ('woooooot"). It happens
while accelerating halfway through 1st gear (AT) from a dead stop
once you've come to a stop, immediately as you enter idle it'll give a short "woot" sound
and finally when you turn the truck off it will usually give another short "woot" sound
This does not happen every day and happens in cold and warm weather. A service bulletin that has the same symptoms while the heating and ac is on has been issued for this vehicle but this happens even with those off. The dealership today told me they can't replicate the problem (of course) so I'm currently at a loss.
dyne is offline
post #2 of 5 Old 07-16-2009, 04:41 PM
jaw22
2011 WK
Have you done anything to the stereo? My last car, apparently I neglected to ground a wire or something somewhere and it made a faint whistling through the speaker the harder i pushed the engine.
2011 Grand Cherokee Laredo X
jaw22 is offline
post #3 of 5 Old 07-16-2009, 06:51 PM Thread Starter
dyne
Everything is stock. Ater getting it home I've somewhat isolated it better. I kept my foot on the brake while putting the truck from park to drive, park to reverse and so on. EVERY time it made the noise. It also seems to be coming from the middle of the vehicle upon closer inspection around the transfer case.
Great Guess I'll be going back up Monday since I can do this at will now.
dyne is offline
post #4 of 5 Old 07-19-2009, 04:37 PM
DCON
2005 WK
I had a similar problem with mine. I had a hole in my manifold, had it replaced and now everything sounds fine.
DCON is offline
post #5 of 5 Old 07-20-2009, 02:20 AM
braleyk
2005 WK
i have a similar, annoying whistle in my hemi that showed up after installing k&n intake. its worst when accelerating at about 1/3 throttle. has anyone else experienced this after installing an intake?
'05 WK HEMI Limited QDII - 970JEEPERS
braleyk is offline
98 GC strange whistling sound when accelerating fletcher1268 ZJ Grand Cherokee Forum 19 03-12-2009 01:59 PM
G. Cherokee Making Bad Noise When Turning fred99x ZJ Grand Cherokee Forum 4 09-20-2007 05:53 PM
2006 V6 Grand Cherokee Laredo Rear Differential Noise strdotmatt ZJ Grand Cherokee Forum 5 07-25-2006 01:26 PM
2001 Grand Cherokee Laredo rattling noise ArcticAlaskan ZJ Grand Cherokee Forum 2 06-11-2006 10:00 AM
Rubbing Noise in Front-end when I hit bumps with my 1999 Jeep Grand Cherokee Laredo cjdietzman WJ Grand Cherokee Forum 9 02-21-2003 08:51 AM
