where in the world is the oil drain plug?
| Rock Krawler Suspension's for BLOW OUT prices!!! | Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com |
#1 | |
i cant find it! im going nuts!
#2 |
Ahhh, welcome to the Grand Cherokee WK forums
On the 4.0 inline 6 it is located at the bottom rear of the oil pan. It's on the back edge, kind of pointing down and back at a 45 degree angle more or less. If your down there you should see it pretty easily. If you have skid plates there should be an access hols there but its possible that you'd have to drop the skid plate to find it.
05 Grand Cherokee Limited 5.7 Hemi 265/65/17 Revos, K&N HEMI CLUB MEMBER #10 Previous Jeeps: 1998 ZJ Special Edition 2wd- Traded 1991 XJ 2.8 2wd Sold |
#3 |
It is on the bottom of the engine oil pan facing the back of the vehicle...
There should be a hole in the plastic engine cover under the vehicle (so you can access it without taking off the plastic shield) and there it is... JW
1998 XJ - built for offroading 2007 WK CRD - DashHawk, for towing the XJ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
