Where is this oil leaking from? - JeepForum.com
post #1 of 10 Old 06-20-2011, 10:00 PM Thread Starter
Dusan
I noticed some oil dripping on the driveway and have smelled burning oil when at the lights. I removed the skid plate and noticed the oil is dripping somewhere right and back of the engine. It seems that it also drips on the catalyst so that explains the smell. Anybody have any ideea where it might come from?
2008 WK CRD
Dusan is offline
post #2 of 10 Old 06-20-2011, 11:41 PM
fatfreddy
2008 WK
2008 WK CRD
Check your CCV hose.It's on the rear of the valve cover on the passenger side.Maybe it came un-hooked.
fatfreddy is offline
post #3 of 10 Old 06-21-2011, 06:54 AM Thread Starter
Dusan
It's not the ccv hose. I took the cover off and cannot see any oil, not around ccv nor anywhere.
Dusan is offline
post #4 of 10 Old 06-21-2011, 06:57 AM
CmmdrDan
Is it motor oil or trans oil. The trans cooler lines usually cause problems like this..
CmmdrDan is offline
post #5 of 10 Old 06-21-2011, 07:19 AM
dcecr
2006 WK
let us know what you find...the burning smell on my 2006 WK (3.7L) is back and its been in the shop three times but they can't figure it out
dcecr is offline
post #6 of 10 Old 06-21-2011, 07:22 AM Thread Starter
Dusan
I'm not sure if it's trans or engine oil. How can I check?
Dusan is offline
post #7 of 10 Old 06-21-2011, 07:27 AM
CmmdrDan
Have them check the sensor in the trans pan. I believe it is at the front of the trans just about the pan. They say the o-ring for the sensor goes bad and it drips right onto the cat. Burning oil smell..No good!
Trans oil is usually a redish tint.
CmmdrDan is offline
post #8 of 10 Old 06-21-2011, 08:07 AM Thread Starter
Dusan
The oil I'm seeing is black.
Dusan is offline
post #9 of 10 Old 06-21-2011, 08:52 AM
AJeepZJ
2006 WK
Not if the person has never changed it and is agressive on the tranny. Then the trans oil can look like fresh oil. But if he's saying the oil is dark... then thats a different story. And, he needs to get the oil changed too, lol.
All Gear, No Skill.
AJeepZJ is offline
post #10 of 10 Old 08-10-2013, 11:26 AM
oldsmoke
2009 WK
Same problem
2008 WK CRD
I have the same thing happening on my Jeep. At first I thought it was the dpf regenerating but then I noticed where oil has been dripping down and burning off of the catalyst at the right rear of the motor. I suspect it is coming from the PCV valve which is right above but I still have warranty so I am going to the dealer and point it out to them.
oldsmoke is offline
oil leak
Leaking ZJ KCJeep ZJ Grand Cherokee Forum 10 09-08-2010 01:00 PM
TC leaking jeepunlimited ZJ Grand Cherokee Forum 10 01-29-2007 08:12 AM
It's leaking !!!!!! vosevichs ZJ Grand Cherokee Forum 10 03-31-2006 08:44 AM
Leaking TC Joseph Humphrey ZJ Grand Cherokee Forum 1 03-17-2004 09:24 AM
