when do I need longer sway bar end links? - JeepForum.com
post #1 of 6 Old 01-29-2013, 11:37 PM Thread Starter
kennymo
Hiw big of a lift will need longer sway bar end links. I have a 2" spacer lift right now. And I plan on going with a 4" lift when I can afford it. I know they make discos but I cant afford those atm either.
kennymo is offline
post #2 of 6 Old 01-30-2013, 05:57 AM
Jeepforthewin
2010 JK Wrangler
if your getting a 4" lift it would be a good idea to get the longer sway bar end links to be on the safe side. may also have to adjust brake line and some other things
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #3 of 6 Old 01-30-2013, 07:43 AM
christiang26
2009 WK
When you get the superlift it comes with extended sway bar links.
christiang26 is offline
post #4 of 6 Old 09-29-2013, 10:47 AM
Flyboys
2015 JK Wrangler
Are most still running stock length sway bar end links with 2" lifts?
2015 Willys JKU
2014 Ram CC Sport
Flyboys is offline
post #5 of 6 Old 09-29-2013, 10:49 AM
Jeepforthewin
2010 JK Wrangler
Yes most are lol atleast I know I am.
post #6 of 6 Old 09-29-2013, 11:30 AM
sk1er18
2007 XK Commander
On the front it doesn't matter because you haven't really changed the range of suspension motion (even with spacers, its not a drastic difference) or the distance between the sway bar and other suspension components. So stock links are fine for the front.
For the rear, same difference. Most kits lift the rear less than 2" (usually 1.5-1.75")to level the vehicle so the difference in relation to the sway bar linkage is minimal. The biggest benefit is disconnecting the rear if you're offroading and running longer shocks, otherwise the sway bar will greatly limit rear articulation.
-Matt
sk1er18 is offline
