Wheels from wj - JeepForum.com
post #1 of 13 Old 11-11-2013, 07:28 AM Thread Starter
w33mud
2006 WK
Wheels from wj
Couple of questions guys. Sure it's been asked before ,sorry, can I get my 8x16's onto a wk? Tyre size is 285/75/16. Will a 2" lift be enough with some front arch cutting?thanks
w33mud is online now
post #2 of 13 Old 11-11-2013, 08:00 AM
Jeepforthewin
2010 JK Wrangler
IIRC a 16" rim will rub on the brake caliper. As far as the lift many people run 285's on the OME lift (2-3" lift). You will need to do the pinch weld mod though. Not to sure what you mean by trimming the front arch?
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #3 of 13 Old 11-11-2013, 09:27 AM
paroxysym
2007 WK
unless you run the 16s with a large enough wheel spacer to push them out past the caliper, i would say no. if youve seen factory 17s on a WK there isnt a whole lot of room betwen the rim and the caliper. only WJ rims that will fit (and look decent IMO) are the rogues or hammerheads
http://wjjeeps.com/wheels.htm
285s or a 33, will need the pinch welds done front and rear with a 2" lift
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #4 of 13 Old 11-11-2013, 10:39 AM Thread Starter
w33mud
2006 WK
Thanks,should have said aftermarket steels,is there any excess metal on the caliper that could be ground off to help?
post #5 of 13 Old 11-11-2013, 11:55 AM Thread Starter
w33mud
2006 WK
Thanks, cut 1.5" off around edge of arch & bumper.
post #6 of 13 Old 11-11-2013, 01:08 PM
Jeepforthewin
2010 JK Wrangler
Ahh. Never seen anyone do it with a WK yet.
post #7 of 13 Old 11-11-2013, 01:14 PM
BoraBora
2015 JK Wrangler
oooo try to put the 16's on there! I'm sure with some caliper grinding and a wheel spacer it would fit. Worth a shot!
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #8 of 13 Old 11-12-2013, 11:00 AM Thread Starter
w33mud
2006 WK
Has no one tried it before?
post #9 of 13 Old 11-12-2013, 11:29 AM
paroxysym
2007 WK
i believe there is maybe one or two running them- but you have to ground down quite a bit to clear the calipers and then if you dont want to do that- the amount of backspacing/wheel spacer youll need to run puts the wheel well outside the fenders, which can cause problems with the authorities
and thats a pic of a WJ up there- you could run a 16 or a 15 on a WJ
OEM+
post #10 of 13 Old 11-12-2013, 11:52 AM Thread Starter
w33mud
2006 WK
Thanks,yea it's mine,fancied another wk and was wondering if my wheel & tyres would fit it.
post #11 of 13 Old 11-12-2013, 12:45 PM
yzjwk
2005 WK
Some 16" rims will fit on some 05-07 wk's . there's a few guys running them if you search around . http://www.jeepforum.com/forum/f67/1...ls-xk-1572355/
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #12 of 13 Old 11-13-2013, 01:49 PM Thread Starter
w33mud
2006 WK
Cool,thanks for that,was looking at 05 's to avoid horrendous road tax we have to pay.
post #13 of 13 Old 12-06-2013, 01:18 AM Thread Starter
w33mud
2006 WK
Didn't clear caliper, gutted
