Which wheels to fit larger tires - Page 2 - JeepForum.com
post #16 of 21 Old 11-20-2013, 07:11 AM
sk1er18
2007 XK Commander
It depends on the tire.... but id still recommend spacers. We put some 245/75/17s on my friends xk; he cleared the bolt with ease but rubbed the unibody at full lock (not the pinch weld)
-Matt
sk1er18 is offline
post #17 of 21 Old 11-20-2013, 07:49 AM
ttusqrl
2005 WK
Originally Posted by msfulcher77 View Post
Thanks for the info. Does that mean, when I lift, I can go with 265/70/17 without spacers on my commander or are there other suspension differences that would still require spacers? I may still go with spacers for the stance, but I want to know is it needed or not. I have the 17" chrome wheels so I'll make sure it's stamped. Thanks.
As mentioned in the renewed "OME vs SL" thread, the XK has a harder time fitting bigger tires (even 265/70/17s). Visit that thread to read up on it.
2005 WK 5.7 ORT | Mod SL (OME struts & 990s) | JBA UCAs & Discos | Saguaro Front Bumper | Warn Zeon 10s | 285/70/17 BFG TA KO | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | JL Stealthbox
ttusqrl is offline
post #18 of 21 Old 11-20-2013, 01:37 PM
msfulcher77
2008 XK Commander
I read that thread and your comments. Thanks. I'm planning on an OME HD lift and putting 265/70/17 ATs on stock wheels. Nothing too crazy. Maybe a General Grabber AT2 with 1.25" wheel spacers. If I ran a mud tire it would be if I came across a great deal on Rubicon take-offs (255/75/17)and I would still use the 1.25" spacers. Thoughts on fit with that scenario assuming pinch weld mod? Tight is ok. I have no desire to go bigger and my wheeling is relatively mild but I will still stuff the tires...
2008 XK Hemi w/QT2
Superchips Flashpaq 3875 running Mileage Tune (for now)
msfulcher77 is offline
post #19 of 21 Old 11-21-2013, 02:24 PM Thread Starter
ohhpe
Any specific examples or links to a good wheel to use like the aev
95 yj 6" lift, 34" truxs mts
2005 WK Limited 5.7L Hemi. 2" day star lift awaiting tires and wheels for installation.
ohhpe is offline
post #20 of 21 Old 11-26-2013, 07:41 PM
grand poobah
2007 XK Commander
The WK/XK specific AEV wheel isn't sold by AEV anymore, however I can confirm that they will accommodate a 265/70/17 tire with no rubbing and no pinch mod..at least on an XK and normal daily driving.
My setup is OME HD, AEV Pintlers and 265/70 Duratracs.
The specs on the WK/XK Pintlers are 17x8.5 with +25mm offset. Any wheel matching that should work. There are also the JK versions which are still available with a +10MM offset, meaning they'll stick out over 1/2 more. I don't know how that will affect rubbing issues
grand poobah is offline
post #21 of 21 Old 11-27-2013, 10:49 AM
BurmaJack
2008 WK
I visited a tire shop last week to purchase some Hurcules Avalanche X-treme studded winter tires 265/70 17's and have them mounted on my stock WK Everest wheels. No lift, no mods.
He called back and said "there is no F'n way" they will fit, even if they trim the bolt. Not enough back spacing apparently.
When I brought up spacers, he said he doesn't like them as they cause the hubs to wear out prematurely. Any truth to this?
'08.5 WK Laredo CRD North Edition; QTII;
Modern Blue Pearl; GDE HOT Tune
Blue WK Club Member #2
BurmaJack is offline
