Which wheels to fit larger tires - JeepForum.com
post #1 of 21 Old 11-18-2013, 07:17 PM Thread Starter
ohhpe
Which wheels should I look at in order to run 265 70 17s? Any suggestions
Not sure on what size and bs I need
95 yj 6" lift, 34" truxs mts
2005 WK Limited 5.7L Hemi. 2" day star lift awaiting tires and wheels for installation.
ohhpe is offline
post #2 of 21 Old 11-18-2013, 07:25 PM
ttusqrl
2005 WK
You can use your stock wheels with that size
2005 WK 5.7 ORT | Mod SL (OME struts & 990s) | JBA UCAs & Discos | Saguaro Front Bumper | Warn Zeon 10s | 285/70/17 BFG TA KO | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | JL Stealthbox
ttusqrl is offline
post #3 of 21 Old 11-18-2013, 07:37 PM Thread Starter
ohhpe
What? Everyone here is saying you can't
ohhpe is offline
post #4 of 21 Old 11-18-2013, 07:38 PM
Jeepforthewin
2010 JK Wrangler
You can use stock wheels as long as you have a spacer.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #5 of 21 Old 11-18-2013, 08:49 PM
Cherokee30D
2007 WK
Or use Jeep Commander rims with no spacers...........
Cherokee30D is offline
post #6 of 21 Old 11-19-2013, 12:56 PM Thread Starter
ohhpe
How do the commander wheels work
ohhpe is offline
post #7 of 21 Old 11-19-2013, 01:20 PM
msfulcher77
2008 XK Commander
How would Commander wheels make a difference? They are 17x7.5 with 6.25" back spacing same as WKs...
2008 XK Hemi w/QT2
Superchips Flashpaq 3875 running Mileage Tune (for now)
msfulcher77 is offline
post #8 of 21 Old 11-19-2013, 01:49 PM
ttusqrl
2005 WK
I apologize if I misunderstood the question. Larger tires will fit on the stock wheels just fine, especially the 265/70/17s you are discussing. Some have said they can fit 265s on the stock setup and just do the pinch weld modification -- no UCA bolt trimming necessary. Others have said that it wants to hit the UCA bolt so they need to trim the bolt or add spacers. This all depends on the tread profile.
Your stock wheels will work just fine for you if you are ok test fitting and possible adding spacers if necessary. If you want to get a new set of tires, then go for it. My point is that it isn't necessary.
ttusqrl is offline
post #9 of 21 Old 11-19-2013, 02:06 PM
Cherokee30D
2007 WK
The Commander wheels work great as per photo below.
The 265/70/17 tyres fit nicely without any modifications at all. If you do put that size tyre on the original wheels, you will need some modifications.
Cheers, Craig
post #10 of 21 Old 11-19-2013, 04:51 PM
sk1er18
2007 XK Commander
They're actually not. The XK wheels are 43.8mm offset (6" BS) vs the WK wheels which are 50.8mm offset (6.25" BS).
So you could run XK wheels in lieu of WK wheels with 1/4" spacers.
-Matt
sk1er18 is offline
post #11 of 21 Old 11-19-2013, 08:24 PM Thread Starter
ohhpe
So any recommended wheels to purchase. I recall the aev pintlers being a good option
ohhpe is offline
post #12 of 21 Old 11-19-2013, 08:42 PM
Jeepforthewin
2010 JK Wrangler
MB TKO's
post #13 of 21 Old 11-19-2013, 09:10 PM
msfulcher77
2008 XK Commander
Originally Posted by sk1er18
They're actually not. The XK wheels are 43.8mm offset (6" BS) vs the WK wheels which are 50.8mm offset (6.25" BS). So you could run XK wheels in lieu of WK wheels with 1/4" spacers.
So... Xkjeeps.com is wrong...? See link below. I haven't measured so I can't speak for certain...
http://www.xkjeeps.com/xk_wheels.htm
2008 XK Hemi w/QT2
post #14 of 21 Old 11-20-2013, 04:15 AM
sk1er18
2007 XK Commander
Yes xkjeeps is wrong. You dont need to measure, you can see the offset stamped on the back of your wheel the next time you rotate your tires.
-Matt
sk1er18 is offline
post #15 of 21 Old 11-20-2013, 06:32 AM
msfulcher77
2008 XK Commander
Thanks for the info. Does that mean, when I lift, I can go with 265/70/17 without spacers on my commander or are there other suspension differences that would still require spacers? I may still go with spacers for the stance, but I want to know is it needed or not. I have the 17" chrome wheels so I'll make sure it's stamped. Thanks.
2008 XK Hemi w/QT2
