Wheel spacer size - JeepForum.com
 1Likes
  • 1 Post By Lenny7
post #1 of 13 Old 02-25-2017, 06:35 PM Thread Starter
Rat609
Wheel spacer size
Does anyone out there run wheel spacers because you like the way they look from a cosmetic standpoint?? running a 2.25 BB with 255/65/17, stock wheels, and 5/16" spacers to clear the uca bolt. im looking at either 1.75" or 2" hubcentric spacers but striclty because i love the wider stance look.. any ideas? pics of your rig with spacers that size??
Rat609 is offline
post #2 of 13 Old 02-26-2017, 12:44 PM
bensylrm
2005 WK
Here's Rikki Tikki Tavi (05) after adding the Rubicon take-offs 255/75R17. OME HD, with MLL's on rear. 1.5 spidertrax on front, 1.75 spidertrax rear. 20170226_134145_hdr.jpg20170226_134132_hdr.jpg20170226_134121_hdr.jpg
Sent from my LG-H810 using Tapatalk
05 WK 4.7 OME HD F150 MLL's, BFG MT 255/75-17. Lots of stickers, lights EVERYWHERE!
bensylrm is online now
post #3 of 13 Old 02-26-2017, 04:51 PM Thread Starter
Rat609
love the way that looks!!! ive seen alot of 2" spacers while shopping around but ive never seen anyone run them... wondering if theres any negatives to going that size or im just the only one that likes the look of the wider stance..
Also if i dont have any issues with rubbing the pinch weld now will i be ok with any size spacers?
Rat609 is offline
post #4 of 13 Old 02-26-2017, 07:28 PM
bensylrm
2005 WK
I will say that my 2 year old wheel bearings are about shot. Spacers of any size do put a higher stress on them, bigger equals more. Just something to think about. Where you are now, with that tire size, you probably wouldn't have any rubbing at the pinch weld. Bigger spacers, or bigger tires, it will become a problem. It's not very difficult to do the pinch weld mod though. I just cut mine with a Sawzall in between each one of the spot welds, then hammered them flat pretty easily with a two pound hammer. I then covered it with undercoating. The wheel well liner I heated up with a heat gun until it was soft and smashed it flat with a 2x4.
I tried to save a couple bucks on the spacers. I went to the part of the spidertrax website that sells spacers with blemishes. I figure I'm going to tear them up pretty good anyway, who cares if they don't look perfect from the get-go.
post #5 of 13 Old 02-26-2017, 07:29 PM
Bama_WJ
Bama_WJ's Avatar
I run 1.25" spidertrax spacers. Made my 265s sit flush with the fender. Looks great.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ
Bama_WJ is offline
post #6 of 13 Old 02-28-2017, 08:13 AM
ruskiybro
2005 WK
I run 265/70/17 BFGs A/T. 2.25 OME full MD kit. Put on 1.5" spacers so it clears the bolt. Love the look, just wish i had gotten 33s that where thicker!
2005 4.7L WK - 2.25 OME - 32" BFG - MBRP - 54" Bar - Kicker - 4xGuard skids
ruskiybro is offline
post #7 of 13 Old 02-28-2017, 08:49 AM
caulk04
2008 WK
The wider you go, the more fender/PW clearance issues you'll have.
I'm running 1.25" and they're just about right to keep my 265 width tires on JK 18" wheels at the edge of the fenders.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #8 of 13 Old 02-28-2017, 10:51 AM
Lenny7
2006 WK
*hubcentric*
bensylrm likes this.
Lenny7 is offline
post #9 of 13 Old 03-10-2017, 03:10 AM
spitt19
Junior Member
spitt19's Avatar
2005 WK
I didn't know spidertrax made 1.25" spacers. I'm looking to go with 1.25. Did you have to trim your lugs on your jeep?
SPITT19
spitt19 is offline
post #10 of 13 Old 03-10-2017, 02:42 PM
caulk04
2008 WK
I have one pair of BORA and one pair of SpiderTrax. One or the other was listed for the WJ but it doesn't matter.
No lug trimming for me. I do not, however, recall if the lugs stick out past the spacers at all. My wheels have a large void there so it's of no concern.
caulk04 is offline
post #11 of 13 Old 03-11-2017, 10:07 AM
hemigc
2005 WK
I have 1 1/4" spacers and the lugs did not need to be trimmed. I almost believe you could use 1" spacers without trimming your lugs.
hemigc is offline
post #12 of 13 Old 03-20-2017, 07:59 PM
Bama_WJ
Bama_WJ's Avatar
No trimming at all.
I think they're just marketed for JKs. Don't know why when there are multiple Jeeps that have the same bolt pattern.
Daniel
Bama_WJ is offline
post #13 of 13 Old 03-21-2017, 08:40 AM
jeepWK2007
2007 WK
I run 1" with 255/75 bfg ko2s and they do rub a tad at full lock. you do NOT need to trim the studs, I even went as far as ordering .75" bora spacers and they did NOT work as the OEM studs were too long. just some food for thought
jeepWK2007 is offline
