wheel bearing - Page 2 - JeepForum.com
post #16 of 24 Old 04-09-2013, 07:43 AM
beaver8785
Yea they are ridiculous for a part that might fail in a year or two
beaver8785 is offline
post #17 of 24 Old 04-13-2013, 12:05 AM Thread Starter
floresnick
2006 XJ Cherokee
thanks guys for all your input i feel stupid now because it was a false alarm took it to the dealer i bought it from to see if our warranty would cover it and it ended up being a rock that got stuck in there... so again guys i thanks for the help with everything!
floresnick is offline
post #18 of 24 Old 10-21-2013, 10:37 PM
LeadvilleJL
I'm having what I think is the same issue as well, started as a squeak on the drivers side and has progressed to a grinding after 4 weeks in town driving. Hub and bearing ordered off eBay for $90. Hope it get here this week.
Sent from my iPod touch using JeepForum
LeadvilleJL is offline
post #19 of 24 Old 10-22-2013, 05:50 AM
croth
2005 WK
Ive replaced all four corners on my 05 in the last four years. Had to replace both rear bearings when the seals failed and doused the brakes in axle lube.
Craig
croth is offline
post #20 of 24 Old 10-22-2013, 10:19 AM
zc911
i am getting a squeel/squeek on harder acceleration, and a loud humming noise that changes with RPM. On rainy days it's quieter haha. I am pretty sure it's a wheel bearing, but they dont have the play that you would normally see in a bad wheel bearing.
Are you guys seeing the same thing?
zc911 is offline
post #21 of 24 Old 10-22-2013, 10:37 AM
ryann04
2008 WK
Originally Posted by beaver8785 View Post
Plan on doing the other side soon or if have the funds do both sides cause when u put a new one in usually throws the other side off a little. Just my two cents.
Do them as pairs. They should never be done one at a time. Chances are if one if toast, the other one is not far behind. It's almost like tires, you never just buy one!
2008 - Jeep Grand Cherokee - 3.0L CRD - Quadra Drive II - GDE Hot-Tune - OME HD Lift Kit - OEM Full Steel Skids
Blue WK Club Member #42 // DIESEL FTW !!!! -Ryan
ryann04 is offline
post #22 of 24 Old 10-22-2013, 07:57 PM
LeadvilleJL
That's good to know, ill have to throw this 1 on just the driver side then upgrade and do them all in a few months. At least ill be good for in town where we only have 2 stop lights for this winter lol.
post #23 of 24 Old 10-22-2013, 07:58 PM
LeadvilleJL
At the same time I'm going to go to long arms in at least the front, I'm sure parts are taking an extra beating on this short arm set up.
post #24 of 24 Old 10-22-2013, 08:01 PM
drrabazz
2007 WK
http://www.jeepsunlimited.com/forums...Writeup-W-Pics
I did mine with a cheap part two years ago. Went bad in 18mos and replaced it again with a timken. Follow instructions above. Axel nut can be loosened with someone holding the brakes.
drrabazz is offline
