wheel bearing - JeepForum.com
post #1 of 24 Old 04-07-2013, 07:50 PM Thread Starter
floresnick
2006 XJ Cherokee
wheel bearing
quick question is the wheel bearings in the Jeep grand cherokee a sealed hub? and how much is a new wheel bearing or will i need to replace the entire hub? dont really know what to ask... just freaking out about it! need help ASAP!!!!!
floresnick is offline
post #2 of 24 Old 04-07-2013, 08:14 PM Thread Starter
floresnick
2006 XJ Cherokee
also want to know how long i can drive on a broken wheel bearing
post #3 of 24 Old 04-07-2013, 08:14 PM
tjkj2002
2002 KJ Liberty
All 4 corners are a sealed hub unit.Your rear axle is actually a full floating diff with a unit bearing bolted to the tubes.
tjkj2002 is offline
post #4 of 24 Old 04-07-2013, 08:15 PM
tjkj2002
2002 KJ Liberty
Not far depending on how bad it is.If it's really bad do not drive it as major damage can and will occur that will increase the repair cost big time.
tjkj2002 is offline
post #5 of 24 Old 04-07-2013, 08:18 PM Thread Starter
floresnick
2006 XJ Cherokee
so i have like a grinding noise in my front wheel when it rotates it makes a grinding sound a mechanic buddy said it was my wheel bearing but only guessed that from a video i sent him of the sound... how much is it going to cost and is it possible to do it by myself?
post #6 of 24 Old 04-07-2013, 08:21 PM Thread Starter
floresnick
2006 XJ Cherokee
well ****... this really sucks i don't know what to do or where to start!
post #7 of 24 Old 04-07-2013, 08:48 PM Thread Starter
floresnick
2006 XJ Cherokee
whats a full bearing gonna cost?
post #8 of 24 Old 04-07-2013, 08:50 PM
NameLikeNoOther
I just did my DS front wheel bearing last night, I had a lot of grinding and noise coming from that side of the vehicle especially when I turned to the left or accelerated. It is a sealed hub unit with wheel speed sensor attached. It is a fairly easy repair to do, there is a youtube tutorial for a WJ which is almost the same.
The hardest part was getting the old wheel hub out, I had to beat on it with a sledge hammer for about an hour before it finally broke free. One thing that was contributing to the noise was the dust shield that was bent and rusty and touching the brake rotor. The dust shield is also a bad design because it helps trap salt in a spot on the steering knuckle it was also a contributing factor to salt getting into the wheel bearing. I got 200,000km out of the factory ones so that's not too bad.
Anyways after doing the DS Wheelhub and rotors and pads I still have a lot of noise coming from the front. The hub was definitely fried but only a portion of noise. I am still trying to figure out what the grinding/humming sound I am getting is from. CV's? Drive Shaft U-Joint?
NameLikeNoOther is offline
post #9 of 24 Old 04-07-2013, 08:55 PM Thread Starter
floresnick
2006 XJ Cherokee
well that sure helps just curious to know how much a new wheel bearing is going to cost? i think i can do it my self but i'm going to take it in tomorrow to see if my warranty will cover it before it expires... but in the event they don't cover this i'll have to do it so i'm curious to know how much the bearing will cost. thanks
post #10 of 24 Old 04-07-2013, 09:19 PM
NameLikeNoOther
A quality wheel hub unit will be about $200. You will also need a 12-point 15mm socket to get the 3 bolts that mount the WH to the steering knuckle and a 36mm socket for the axle nut. There are a few write up on here about the change and the youtube video from the 1aauto guy is pretty good. Maybe a good time to service your brakes while you there too.
post #11 of 24 Old 04-07-2013, 10:58 PM Thread Starter
floresnick
2006 XJ Cherokee
alright thanks... is there anyway you can send me a pic of the wheel hub... ive seen a lot of photos but don't know exactly what i'm looking for!
post #12 of 24 Old 04-08-2013, 06:21 AM
XK1982
2006 XK Commander
Rock Auto stocks them from anywhere from $85 - 172. Here's a pic of the back of the unit bearing where it bolts to the knuckle. Also you get all new wheel studs with it and the ABS wire.
2006 XK Commander, 4.7L V8, Quadra-Trac II, 6.25" Modified Superlift, Jeepin by Al's front UCA's, Rusty's Adjustable rear LCA's; 35x12.5R17 TOYO Open Country MT's; Method NV305 17x8.5 wheels
XK1982 is offline
post #13 of 24 Old 04-08-2013, 09:28 PM
Tbonfire
2006 WK
I just got a front wheel bearing replaced in my 06 last week. I opted for the high quality part and with labor it came to $270
Tbonfire is offline
post #14 of 24 Old 04-09-2013, 06:02 AM
beaver8785
Plan on doing the other side soon or if have the funds do both sides cause when u put a new one in usually throws the other side off a little. Just my two cents.
beaver8785 is offline
post #15 of 24 Old 04-09-2013, 06:04 AM
Tbonfire
2006 WK
Yea I will be. $270 broke the bank a bit for now lol
Tbonfire is offline
