Whats a fair price? - JeepForum.com
post #1 of 6 Old 04-26-2013, 09:57 AM Thread Starter
toymachine456
2006 WK
Whats a fair price?
Attempting to install my ome hd this morning and have had zero success.
All bolts are completely seized and rusted solid. Im a little upset about it, I really wanted to do the install myself but Im out of options. Ive contacted multiple shops for estimates. Has anyone had there ome lift installed professionally and if so what did you pay and what would be a fair price for the install.
Thanks ahead of time!
toymachine456 is offline
post #2 of 6 Old 04-26-2013, 12:06 PM
twistedlizard72
2007 WK
It shouldn't be much more than a strut and shock replacement.
Kevin K.
twistedlizard72 is offline
post #3 of 6 Old 04-26-2013, 01:39 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Well if you can put it off a few days or maybe do it next weekend, try spaying PB Blaster on all the bolts a couple times a day for the next few days. That should help you out a lot!
Omelet is offline
post #4 of 6 Old 04-26-2013, 06:37 PM
tjkj2002
2002 KJ Liberty
Be prepared to pay alot more for labor and parts(new bolts and such) since the shop will attempt also and stop when they find all the bolts are seized and call you.Then you will on the hook to either take it back un-installed or buy what breaks and the extra labor.
If the tech stops before breaking a bolt and they contact you your on the hook for what happens if it does break and they should explain this to you and give a option to continue or stop all together.
tjkj2002 is offline
post #5 of 6 Old 04-26-2013, 07:02 PM
Jaashua
2005 WK
My father owns a shop and he spent about 4 hours on one bolt for my struts. He eventually got it out but had I been anyone else he said he would of made me buy a hole bunch of expensive parts instead of dealing with that one bolt. Or at least made me pay all that extra labor.
Sent from my Samsung S2 using JeepForum
Jaashua is offline
post #6 of 6 Old 04-26-2013, 07:10 PM
toycam
One of the things I do if I have a bolt on a jet that is barely moving or isn't at all, try spraying a whole bunch of wd40 or other grease as far onto the shaft of the bolt as you can. If you hammer it out about 1mm, spray more of the now-exposed shaft and hit it back in. Rinse and repeat until it comes further and further out each time. It sucks, but its worked for me on several occasions.
| '05 4.7L V8 | OME HD | Matrix 4xGuard | 4xGuard Front Skid | 265/70/17 TreadWright M/Ts |
toycam is offline
grand cherokee , installation , jeep wk , ome hd , OME lift kit
