What Tires do you use on your Jeep WK? - Page 4 - JeepForum.com
 1Likes
post #46 of 63 Old 08-21-2013, 09:48 AM
NDSU_Bison
2014 WK
My offroading is limited to the ocean beaches and I went with the Goodyear Fortera SilentArmor. They have good traction on wet pavement (most common where I live) and in the snow and are nice and quiet on the highway.
I had Pirelli Scorpions on my old Durango and they were great in the rain and not so good in the snow.
NDSU_Bison is offline
post #47 of 63 Old 08-21-2013, 10:06 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Originally Posted by modernblueWK View Post
How are those authorities on ice and in deep snow?
Actually, the last couple winters we've had significant snows and deep snow they're great - they are marked with the mountain snowflake symbol as well as the "M+S" marking.
Ice - w/o studs show me a tire that is great. Driving on ice is more about how you drive because if you don't do it safely it doesn't matter what tire is under the rig.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #48 of 63 Old 08-21-2013, 11:05 AM
johngreen1234
2010 WK
My experience with the Fortera HL has been so good that I'm about to buy a new set at 50k. The only other tire I'm still considering is the Michelin LTX. Most of my driving is highway and I'm convinced that the Forteras are part of othe reason I'm getting such spooky good MPG (18 overall, 20 on road trips to the mountains).
While I'd prefer a more aggressive M+S, I've had no problems grinding the Forteras through snow and ice on mountain passes. I will concede that they are not the best tire for rain puddles, but the 245/65 is wide enough that its own profile is adding to the flotation problem, IMO. And I LOVE the profile for general highway driving.
Personally I've had it with heavier load-range tires, and will stick with "P" series. IMO you give away too much sidewall "feel" in turns, and you gain a lot of MPG-robbing weight. OTOH, I have to check my tires after every sidewall scuff.
johngreen1234 is offline
post #49 of 63 Old 08-21-2013, 05:15 PM
Walt
2008 WK
The factory GY Fortera HL's were comfortable, OK in rain/light snow, but wore out quickly (40K miles). I'm much happier with the Michelins for the same $$ and they should be good for over 60K miles. See sig below (they are stock size).
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #50 of 63 Old 08-25-2013, 10:22 AM
Kman09JGC
I put a set of 255/65/17 General Grabber at2's on my 09 4.7. Stock fortera's were bad in the rain and snow. Generals are night and day from the stock goodyears and awesome in the snow.
Kman09JGC is offline
post #51 of 63 Old 08-25-2013, 12:34 PM
modernblueWK
245/70-17 grabber at2's here. Really happy so far.
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #52 of 63 Old 08-25-2013, 05:09 PM
R4TCHET
2005 WK
275-65-18 duratracs with 1.25" spacers front and rear. 2" rc lift with pinch weld and rear fender rolled. My rear springs are sagging pretty bad but the fit fine with only some rub on back at full flex. I think once I get an adjustable track bar it won't rub, all I need is my OME springs
Great tires off road and in wet or snowy conditions, on road mine are a bit noisy but not as bad as my mud terrains were. They have about 40% life left on them
Sent from my Jailbroken iPhone using JeepForum
| (dark)KHAKI WK CLUB MEMBER 17 | 2005 4.7L QTII | JBA UCAs | Modified OME MD 3.5" lift | Rusty's Adj. track bar | 4XG Matrix | 285/70r17 Duratracs | 17" KMC Enduro Wheels | Rola Roof Rack | 21" Bean LED Light bar on Roof Rack | 2 12" Punch P3 Subs | Expanded Sheet Grille | SA Sliders |
R4TCHET is offline
post #53 of 63 Old 08-26-2013, 08:11 AM
LouC
2007 WK
Any rubbing with the AT2s in the 255 width? I will need new tires next year and have the AT2s on my old 98 ZJ and am a big fan of them. I could go either 245-70-17 (taller sidewall) or the 255s (wider and just slightly taller sidewall). The Generals on my ZJ are great aired down in fine deep beach sand. They do not dig and you can basically go anywhere you want.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
post #54 of 63 Old 08-26-2013, 08:47 AM
Jeepforthewin
2010 JK Wrangler
I have 265/70/17 Hankook Dynapro ATM's and I love them. I only have minimal rubbing at full lock with no pinch weld mof but i also have aftermarket rims with a larger offset than stock. I went down to the mud pits in my area and never had a problem with the tires getting me stuck or anything. Little road noise also!
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #55 of 63 Old 08-26-2013, 01:07 PM
modernblueWK
245/70-17 grabber at2's no rub no issues. Speedo only off by 2 mph.
SOLD 2008 WK 4.7 V8
post #56 of 63 Old 08-28-2013, 05:28 AM
Kman09JGC
No rubbing at all with 255/65/17. I have had the at2's on for about 10 months now and no rubbing. Buddy of mine put some Bilstein 5100's and Front and Rear srt sway bars so I had him trim the bolt just to give it more room. He checked the inside of the tire and there were no marks.
post #57 of 63 Old 08-28-2013, 09:30 AM
DarthJeep
2005 WK
I have the same tires/size. Haven't put them on. But out of curiosity, what's the backspacing on your rims. I have stock rims with 1 in. Spacers arriving this week.
Build Thread -
Black Wk Club 166
DarthJeep is offline
post #58 of 63 Old 08-28-2013, 10:45 AM
Jeepforthewin
2010 JK Wrangler
The offset on mine is -6 and is 4.51 inches of backspace
post #59 of 63 Old 08-28-2013, 12:35 PM
JRLT
2010 WK
Just ordered my 2nd set of Nitto Terra Grapplers, 1st time using Discount Tire Direct.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #60 of 63 Old 08-28-2013, 01:29 PM
DarthJeep
2005 WK
Jeepforthewin, -6mm? Offset. Are they Pro Comps? 17 x 8.5?
Build Thread -
Black Wk Club 166
Best tires for Jeep Grand Cherokee hunchback WJ Grand Cherokee Forum 35 11-11-2015 09:58 PM
Jeep Wheels/tires Question.. Jason117 WK Grand Cherokee & XK Commander Forum 7 09-27-2009 03:01 AM
Tires for my jeep NudistJeepChick ZJ Grand Cherokee Forum 15 11-04-2007 08:16 PM
New Tires for my Jeep rollin2447 ZJ Grand Cherokee Forum 12 07-20-2005 02:24 PM
New Tires for the Jeep adgjqetuo ZJ Grand Cherokee Forum 5 02-09-2005 05:37 PM
