What tire sizes on a 2007 Jeep GC Laredo? - JeepForum.com
post #1 of 9 Old 06-16-2013, 07:12 PM Thread Starter
SriRamJaiRam
2007 WK
I have a 2007 Jeep GC Laredo 2WD Laredo V6 3.7L w/ a 2" front lift only. I'm running the stock 17" wheels w/ no spacers. Can I fit a 265/70/17 tire w/ out any rubbing?
SriRamJaiRam is offline
post #2 of 9 Old 06-16-2013, 07:15 PM
Tbonfire
2006 WK
All terrain or mud tires?
Tbonfire is offline
post #3 of 9 Old 06-16-2013, 11:19 PM Thread Starter
SriRamJaiRam
2007 WK
Not sure yet... Could go either way. I may be able to buy a used set of Nitto Terra Grapplers in 265/70/17. Would those fit with out spacers on a stock wheel with just a 2" lift in the front? No lift in the rear.
post #4 of 9 Old 06-16-2013, 11:26 PM
Tbonfire
2006 WK
I believe you will need spacers to clear the UCA bolt and wheel spacers. I have Dunlop fierce attitude m-t 265-70-17 with 1.5" wheel spacers and they rub slightly on the wheel well not hitting any metal just the plastic. I have the rro 2.5" lift
Tbonfire is offline
post #5 of 9 Old 06-16-2013, 11:40 PM Thread Starter
SriRamJaiRam
2007 WK
Thanks for the input. If that's the case, what if I go with a 255/70/17? Will that work with no spacers?
Or I could go with a 1.25" wheel spacer with that 265, but will that tire size stick out past the wheel well in any way? I don't want that look as I want the mods to look super subtle. Can you run just a spacer in the front and not the rear? The fronts look like they sit inside the wheel well more than the rears.
post #6 of 9 Old 06-16-2013, 11:47 PM
Tbonfire
2006 WK
1.25 will be barely outside the wheel well but it gives it a beefier stance. 255's should work just fine for you. This is with 1.5" spacers and 265's
Tbonfire is offline
post #7 of 9 Old 06-16-2013, 11:56 PM Thread Starter
SriRamJaiRam
2007 WK
Thanks for the pics! What kind of tires are you running?
post #8 of 9 Old 06-17-2013, 08:41 AM
Tbonfire
2006 WK
No problem! They are Dunlop fierce attitude m/t. They are a great tire! During the winter I was driving threw fields with 2-3 foot of snow and now they just tear threw the mud. Also they are very quiet for mud tire
Tbonfire is offline
post #9 of 9 Old 06-17-2013, 05:26 PM
giulio17
I have 265/70r17 on mine with a rc lift and all I did was cut the Uca bolt and everything clears just fine.
giulio17 is offline
