> Models
> Jeep Grand Cherokee & Commander Forums
> WK Grand Cherokee & XK Commander Forum
What should be done at 100,000miles
08-09-2012, 05:30 PM
#1
So my sisters 05 WK 2wd is at 100k and she has no idea what the service history is of it, she doesnt pay attention when she takes it in. She says she doesnt remember anything being done besides oil changes. I she should be coming to visit next month and I want to take care of the service for her.
What should I look at doing?
What fluids should I change? I am sure the airfilter is long past due to be changed. I know the brakes are fine, she just had them replaced.
Also, every know and then the WK goes into limp mode and the check engine light comes on. If she turns the car off for about 10 min and restarts it, it clears. Any ideas?
85 CJ-7: 2 inch body lift, Weber Carb, 33 inch tires
07 WK Limited: 4.7, QT-II
08-09-2012, 06:25 PM
#2
Was the 90k service done? If not- I'd change your spark plugs, all drivetrain fluids (diffs, tcase, tranny), flush your coolant, maybe do your power steering fluid and check your belt.
2007.5 WK Laredo 4.7
Lifted and Stuff
08-09-2012, 06:29 PM
#3
I will have to ask her, but i doubt it. Thanks.
08-10-2012, 07:00 AM
#4
Here is a great link for maintenance items....
http://www.wkjeeps.com/wk_maintenance.htm
I would do everything and prepare to spend some money.....but in the long run it will be cheaper than buying a new car or making car payments.
Quick list of things needing done...
Coolant system...replace anti-freeze
Transmission service, filter and fluid
Rear diff needs to be changed
oil and filter
air filter
serpentine drive belt
spark plugs
All of this you could do yourself to save money.
Silver WK Club Member #1
2008 CRD QT2
08-10-2012, 09:41 AM
#5
thanks, yeah, i have done must of that stuff before on my cars. I might just have to trade her cars for a week or so.
08-10-2012, 06:49 PM
#6
Should the belt be replaced every 100k miles? Or just need to have them checked at every 3k miles oil change?
08-10-2012, 07:18 PM
#7
No need to replace the belt on a set schedule. Inspect it regularly (at every oil change works fine) and change it when it's worn.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
08-10-2012, 07:34 PM
#8
For $60 it is cheap insurance to me.....
2008 CRD QT2
08-10-2012, 07:43 PM
#9
Or at least get the belt to keep for a replacement in a pinch. Or install the new one and keep the old one for a spare.
91 YJ
98 XJ 2 door love The U.S. Army vaguely envisioned something bigger than a motorcycle, smaller than a truck, and undaunted by the most difficult terrain.
08-10-2012, 10:08 PM
#10
If you have a dealer install the new belt remind them upfront you want the old belt....they will cut the old one off.
2008 CRD QT2
08-11-2012, 05:59 PM
#11
Personally .. I would go look what the engine error code is. That would be the priority.
Get HER records and see what she has done.
Inspect and change "if needed"... not just change things.
08-11-2012, 06:56 PM
#12
Thanks
08-12-2012, 08:40 AM
#13
That doesn't surprise me but it's more work to cut if off because you still have to loosen the tensioner accessory to get the new one on and tight.
91 YJ
08-12-2012, 08:02 PM
#14
I did all fluids including both diffs, TC, and transmission along with spark plugs. Also got a new battery since the it was on the original and tested weak.
