Quantcast what is the purpose of the valet key? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > what is the purpose of the valet key?
Old 06-06-2009, 09:37 AM   #1
konarider94
2005 WK
So i found a key in my jeep that says valet on it. Its just a metal key with obviously no sentry on it so the vehicle will not drive with it. I only have one real key and the only purpose i can see for this one is that it will open the door if i happen to lock the real key inside my jeep.
1994 XJ 2 Door SOLD =(
3"AAL 31x10.5 BFG AT AX-15 NP231
2005 WK Limited 5.7L
245/75-17 goodyear silent armors
no lift, spacers, or cutting required
konarider94 is offline   Reply With Quote
Old 06-06-2009, 10:31 AM   #2
colinzj
2006 WK
Are you sure it's not a Sentry key? The sentry guts don't take much room at all. A valet key is meant to open the door and start the car, but not open the glovebox (or trunk if it weren't a Jeep).
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L — Dead, sold, and rolling again
colinzj is offline   Reply With Quote
Old 06-06-2009, 01:06 PM   #3
konarider94
2005 WK
im positive its not a sentry key. it is a flat piece of metal like a house key
Old 06-06-2009, 01:45 PM   #4
suzieque
2008 WK
I'd have to scan the owners manual again, but I thought the key only opened the hatch and the doors. It cannot be used to start the vehicle.
2008 WK "S" Limited bright metallic silver, 5 speed W5J400 transmission, June 18/2008 build, 213RE rear differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, 3.0L CRD.
suzieque is offline   Reply With Quote
Old 06-06-2009, 02:00 PM   #5
konarider94
2005 WK
it opens the vehicle and will start it but the engine will die almost immediately. which makes sense because its not a sentry key. so is the only purpose to open a locked door? i dont understand why its called a valet key.
Old 06-06-2009, 04:37 PM   #6
kudah
It's flat so you can keep it in your wallet. It's called a valet key b/c it will get you in your Jeep when the brain dead valet locks your keys in it.
Robert
kudah is offline   Reply With Quote
Old 06-06-2009, 07:05 PM   #7
sithlord3
2005 WK
since I dont know if you bought it used or what heres what I have to say..out of curiosity I had a regular old key made copied from the key with remote and such, and what your describing is exactly what the copy does. Opens everything and starts the car for like 5 seconds....sounds like you've found a copy....i couldnt stomach paying 150 bux for a key...insane...
sithlord3 is offline   Reply With Quote
Old 06-07-2009, 09:00 PM   #8
oldmac1
2011 WK
The valet key in my 09 opens the front door lock and locks the glovebox. When you use the valet key to open the door all is good until you actually pull on the door and then the horn starts honking like mad. The old sentry alarm gotcha. I put mine in my wallet in case I ever lock myself out. To get a new key you have to buy the new style fob from Chrysler for 190 bucks so stated the dealer.
Oldmac1
11 GC Overland
08 Liberty
08 Rubicon Unlimited
oldmac1 is offline   Reply With Quote
Glock Forum
