What is this Piece called? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > What is this Piece called?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAwesome savings at openboxoffroad.comNitro Gear Packages Now Available at Rockridge 4wd
Unread Today, 10:38 AM   #1
OzzyNF
2005 WK
im looking for this piece for my driveshaft, not sure if u can buy it separate or not but im sure somebody here will know ... let me know what its called bc I cannot find a name for it in the book.
OzzyNF is offline   Reply With Quote Quick reply to this message
Unread Today, 10:42 AM   #2
2005WK37David
2014 WK
Is it the "half shaft" going from the front axle to the wheel?
2005WK37David is offline   Reply With Quote Quick reply to this message
Unread Today, 11:00 AM   #3
Carlson05
2005 WK
nah that's going from the front driveshaft to the transfer case. I think autozone has a rebuild kit for them about 150 bucks? Idk. http://www.autozone.com/drivetrain/d...mString=search
2005 Jeep Grand Cherokee 4.7 QTII
245:65:17 Cooper AT3's
OME 2.5'' lift w/bilstein 4600 struts.
Carlson05 is offline   Reply With Quote Quick reply to this message
Unread Today, 11:03 AM   #4
2005WK37David
2014 WK
Oh so it is half of the front driveshaft?
When I had to replace mine I got one from the junkyard for $50
Unread Today, 11:04 AM   #5
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Just buy a front drive shaft from a bone yard. Money ahead and you can usually find one with relatively low miles.
Absolutely no reason to spend 150 bucks on a rebuild kit IMO.
~Mike~
My Build Thread WK
My Other Build Thread XJ
'01 XJ with some stuff
Sept 2013 Cherokee of the Month
'07 WK with some other stuff
~RED WK CLUB #7~
'11 KK with mostly stock stuff
'06WK our first Jeep with stock stuff - totalled and gone
JeepN4KC is offline   Reply With Quote Quick reply to this message
Unread Today, 11:30 AM   #6
E_Runs
2007 WK
Like mentioned above, make sure the donor has less miles than what you're replacing. Otherwise you could wind up with the same issue before long.
Bilstien 5100s and rear coil spacers - Sonnax line pressure booster - LED interior lights
E_Runs is offline   Reply With Quote Quick reply to this message
Unread Today, 02:01 PM   #7
OzzyNF
2005 WK
the cv rebuild kit don't include the shaft in the picture I don't think, if it does I cannot find it.... it is indeed the one from the transfer case...any aftermarket vendors sell this piece?
