What performance upgrades do I need? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > What performance upgrades do I need?
Smittybilt Hard Tops @ Oconee Off-Road! 706-534-9955XHD Heavy-Duty Hood Latches for JK and TJ available at OcoFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 07-28-2014, 08:48 PM   #1
Scoops42
2008 WK
So I finally figured out the issue with the borla exhaust, just installed the cold air kit, going to get tuned with the diablo tuner this week. What else do I need? I'd like it to run a 15.2ish. Where else should I go with it?
Scoops42 is offline   Reply With Quote
Unread 07-28-2014, 09:47 PM   #2
Kolak
Vendor
Kolak's Avatar
I have great pricing on Diablo if you didn't already purchase that. Send me a PM.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
kolak@aol.com or kolak@kolakperformance.com
Kolak is offline   Reply With Quote
Unread 07-29-2014, 12:21 AM   #3
unobtanium
2010 WK
My question is...why are these things so bloody slow? They have plenty of power/weight ratio to be much faster. I mean, the Ford Explorer Sport has 8hp more, 40#tq less, and weighs within a hundred pounds or so the same, is also AWD, and is a full second faster 0-60, and maintains that lead through the 1/4 mile along with about a 5mph trap-speed bettering. Where did Jeep screw up?
No repairs in 30 days and counting! Nirvana!
*Scratch that, 7/30, HEEP broke again. Fail.
unobtanium is offline   Reply With Quote
Unread 07-29-2014, 04:43 AM   #4
Hendrix9
2007 WK
Transmission gearing. The explorer sport has 4.84 - 2.87- 1.84- 1.4- 1.0- 0.74 with a 3.16 final drive ratio. That really makes a difference over the jeep with the 545rfe's 3- 1.67- 1- 0.75 - 0.67 even with 3.73s. Torque multiplication is king. (Not to mention the 3.5 tt's nice torque curve certainly helps some)
2007 CRD QDII
4XGuard Matrix, GDE Eco Tune
DPF delete, RC 2.5 lift on 265/70/17s
Hendrix9 is offline   Reply With Quote
Unread 07-29-2014, 05:47 AM   #5
unobtanium
2010 WK
I understand gearing, and that makes sense, but a full second and 5mph trap speed? Gears do not give you that kind of performance difference. They might help ET, but they do NOT give you 5mph more trap speed. Actually, it looks more like 5-8mph trap-speed looking at 1/4 mile times for the vehicles.
I get that 0-60 the Sport has a mad advantage, but that isn't enough to give it a 5mph higher trap speed. Using your math, if I find an Explorer Sport on the freeway and punch it and we both end up in 1:1, I should stomp it because I have better rear-end gearing. I simply am NOT confident in that result...it sounds very hokus pokus.
The ONLY thing I will buy is that the Explorer Sport has a rediculous stall converter and the testers torque-braked it to 3200rpm and launched the living hell out of it and that on the street day-to-day it won't come anywhere near the numbers I've seen from auto mags.
Or there is more to it than just gearing. The Jeep's gears really are not bad given the medium sized V8 and decent torque curve.
WAIT:
Maybe I don't understand what our Jeeps do, it is my impression that they:
0-60: 7.0s
1/4 mile:15.0@92mph
Is this correct for a 4x4 5.7L 2009-2010?
Unread 07-29-2014, 05:53 AM   #6
paroxysym
2007 WK
definitely the tranny. i mean you have the hemi so it should be pretty quick- youve done exhaust, tuner, and intake. start looking into some SRT bolt-ons if youre looking for speed... the manifold, throttle body, headers, etc. after that, id start looking into modding the tranny. fortunately for the SRT guys W5A580 tranny, which the 3.7 also has- all they need to do is throw the blue top solenoids(brings the tranny to AMG spec) in them and theyre good to go. wish the 545RFE was easily modified, all you can do is a tune and the line pressure mod.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline   Reply With Quote
Unread 07-29-2014, 06:20 AM   #7
unobtanium
2010 WK
Line pressure mod?
Unread 07-29-2014, 06:32 AM   #8
paroxysym
2007 WK
Originally Posted by unobtanium View Post
Line pressure mod?
yep
http://www.airram.com/parts.php?query=sonnax
OEM+
Unread 07-29-2014, 06:50 AM   #9
unobtanium
2010 WK
Originally Posted by paroxysym View Post
When used without a tune or anything else, how does this affect long-term durability of the transmission? :/
Unread 07-29-2014, 07:04 AM   #10
paroxysym
2007 WK
apparently it doesnt effect anything long term- if anything it increases the line pressure, firming up the shifts which will create less where on the tranny.
OEM+
Unread 07-29-2014, 01:04 PM   #11
Scoops42
2008 WK
doesnt the predator accomplish the same thing?
Unread 07-29-2014, 03:39 PM   #12
Kman09JGC
Kman09JGC's Avatar
If I'm running Superchip 91 perf tune with trans app do I need to go back to stock and run with the line pressure booster for a couple weeks or can I install it with the tune in?
09 laredo 28x 4.7 w/QD2 Superchip w/91 perf tune w/ trans app, jet 180 tstat,K&N CAI, bistein 5100 struts and shocks, srt8 front and rear swaybars, 255/65/17 General Grabber at2's.
Black WK Club #107
Kman09JGC is online now   Reply With Quote
Unread 07-30-2014, 01:58 PM   #13
luckyse7ens
2010 XK Commander
Whoa this is news to me!
Where do I find these?
Black WK Club #152
luckyse7ens is offline   Reply With Quote
Unread 07-30-2014, 02:17 PM   #14
paroxysym
2007 WK
http://www.amazon.com/MB-Solenoid-Ga.../dp/B009HC5LCE, i have not done any research into these. a buddy of mine that owns a SRT told me he was doing this with his SRT.
as for running the sonnax with a tuner, im pretty sure a few people on here run it with a tunner- i.e. Nate and his Bison
OEM+
Unread 07-30-2014, 02:31 PM   #15
luckyse7ens
2010 XK Commander
That appears to be a very interesting mod for the poor little 3.7l.
3.73's and the 'noids would really help this heavy rig.
The solenoids are more expensive than I had hoped unfortunately
Have to convince the wife it will improve MPG and tranny longevity.
I see its here as well:
http://www.smallfleetparts.com/MB-So.../dp/B009HC5LCE
http://www.smallfleetparts.com/AMG-M.../dp/B009HCCIZW
I feel like this mod deserves its own thread. Sad they didn't use this trans with the HEMI.
Black WK Club #152
