What happens when I remove my battery???Need HELP FAST - JeepForum.com
post #1 of 16 Old 08-02-2013, 03:49 AM Thread Starter
hdsport
2008 WK
I just got my 2008 GC Limited and the battery needs to be replaced.
I am VERY concerned that if I just "take out" the old battery and install a new battery, I will "loose" something in the electronics 'memory' in the Jeep.
eg.; like radio settings, navagation, computer memory, etc. etc.
This is really scary to me.
SO, is this a concern and, if so, what / how do I do it???
I have a cigarette lighter plug w/ a 9v battery attached that I used in my older vehicles to maintain the memories in them when I did a battery switch.
Is this what I need to do with the 2008?
I also thought about attaching a trickle (maintenance) charger to the terminals through the whole process so I would have some electricity going into the Jeep while the battery was out.
Anyone recommend this / or has ever done this??
So, please respond with your advice or recommendations.
I will attempt to do this later today.
Thanks for your time.
Regards,
Paul
2001 Winnebago Adventurer 32v Motor Home
2008 Jeep GC Limited Toad, 4.7 L V-8, QTII
US Army Vet, 8th Army, 11th Evac SMBL Hospital, Pusan, South Korea
In God We Trust
hdsport is offline
post #2 of 16 Old 08-02-2013, 04:05 AM
sunoff
2010 WK
actually wondering about something similar....new to me car...should I unplug battery and let it learn me?
now to op.... stop freaakn out. u have a good vehicle and thousands of friends......ur good.
not stock WK and still working on it
almost modified OME HD
bunch of heavy crap
Superlift ordered
sunoff is offline
post #3 of 16 Old 08-02-2013, 04:39 AM
BoraBora
2015 JK Wrangler
If you're that scared of doing it, you could get the dealership or BP to change it for you.
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #4 of 16 Old 08-02-2013, 04:55 AM Thread Starter
hdsport
2008 WK
Not afraid, just wise enough to seek advice about things that I am not sure of so I can do the task correctly, ONCE.
I have spent more time under the hood than most and have learned it is much better to do things the right way...saves a lot of future rework and problems.
I appreciate your advice, but this is one job that I will do on my own.
In God We Trust
hdsport is offline
post #5 of 16 Old 08-02-2013, 05:38 AM
BoraBora
2015 JK Wrangler
I like that attitude. I wish I had the courage to work on my own car without fear of messing it up.
BoraBora is offline
post #6 of 16 Old 08-02-2013, 06:27 AM
BAH101
2008 WK
You will most likely lose you radio settings. Easy to reprogram. As for the computer and other electronics, nope. Do you lose all your memory from your desktop or laptop when you unplug it? You're just changing a battery, one in, one out...if you where leaving it out for a year, that might be a problem.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #7 of 16 Old 08-02-2013, 06:38 AM
tjkj2002
2002 KJ Liberty
The cigarette lighter plug w/ a 9v battery type of memory saver will not work on a WK,you need a memory saver that plugs into the OBDII port.
If no memory saver is used you will loose the radio memory and all "learned" memory in the pCM so the engine and trans will act a little funny for a few days until it re-learns your driving habits.
tjkj2002 is offline
post #8 of 16 Old 08-02-2013, 06:48 AM
Pac Man
Pac Man's Avatar
Radio/nav settings will be retained due to an internal battery in the radio. PCM/TCM settings will be lost and have to be relearned. No big deal.
2007 Black Grand Cherokee
Hemi - QDII - OME - S4XC Hidden Winch Mount -Talon 9.5SR - Full Matrix - 265/70/17 Duratrac's - Pintlers- Superchips - Magnaflow - Airaid - 5000k HIDs - Lightforce HID's - 4xG Front Guard - 4XG Diff Cover
Pac Man is offline
post #9 of 16 Old 08-02-2013, 07:24 AM
LJS8510
LJS8510's Avatar
2015 WK
Once my MY GIG went dead, I disconnected battery & reconnected. My Gig restated, had to reset presets but everything else was there.
However one time I had it in the dealership. they needed to disconnect battery and I was warned ahead of time that My Gig unit may not restart and they are not responsible.
They went and did it & I had no problems but they did give the warning so it must happen at times.
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #10 of 16 Old 08-02-2013, 07:48 AM
johngreen1234
2010 WK
PCM gets reset, which can be desirable. Radio loses clock settings and current prefs but NOT loaded media data or playlists. Disconnecting the battery is the recommended precaution (here, at least) when messing with anything electrical.
johngreen1234 is offline
post #11 of 16 Old 08-02-2013, 08:03 AM
ca07wk
2007 WK
Everytime I've unplugged my battery I lose the radio clock setting but not presets, and the MPG/trip gets reset.
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #12 of 16 Old 08-02-2013, 11:58 AM
Jeepforthewin
2010 JK Wrangler
I have an aftermarket radio installed and i lose my presets and clock. Other than that the only thing I lose is my MPG's on the EVIC which is no biggie.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #13 of 16 Old 08-02-2013, 04:10 PM
duneslider
On my 2010 I just recently changed mine out and it didn't even lose the stuff in the evic. I don't think anything was lost.
Is it really that big of a deal if you lose your radio stations?
duneslider is offline
post #14 of 16 Old 08-02-2013, 06:45 PM Thread Starter
hdsport
2008 WK
Update
Thanks for all of the input.
I considered all options as well as the comments made by the service managers at 3 Jeep dealerships (???).
So, selecting the best of all, I got all of my tools ready.
I placed a 9v battery set-up into the 12v power outlet (cheap insurance if it does anything)
Loosened the hold-down.
Loosened the two terminal connectors and moved them aside to a safe place.
Removed a very heavy battery.
Placed the new battery in position and tightened the hold-down.
Connected the two terminals and tightened both connectors.
JOB DONE!!!!!
Next, checked:
Radio - all preset channels were there
Navagation - all presets were there
Drivers seat memory - # 1 & 2 were there
Haven't got to the trip odometer, yet.
So, all went well and my Jeep has a new battery.
Thanks again for all of your help.
Paul
In God We Trust
hdsport is offline
post #15 of 16 Old 08-02-2013, 08:00 PM
BurmaJack
2008 WK
I played my stereo out at the lake once and killed the battery. I boosted it to get it started, and the only things I noticed was the "hours" counter on the evic reset itself to zero, and I got an "transmission Overtemp" message too, however it went out after a minute or so and has never appeared again.
'08.5 WK Laredo CRD North Edition; QTII;
Modern Blue Pearl; GDE HOT Tune
Blue WK Club Member #2
BurmaJack is offline
