What is a good battery for SUB-ZERo temps? - JeepForum.com
post #1 of 19 Old 11-11-2012, 06:23 PM Thread Starter
Tango.
2008 WK
When it gets REALLY cold what is a good battery?
Cold like minus 30.
THis is for a diesel.
Tango. is offline
post #2 of 19 Old 11-11-2012, 07:11 PM
Mainsail
2005 WK
I think you need a battery warmer.
Poor grammar is something up with which I shall not put.
Mainsail is offline
post #3 of 19 Old 11-11-2012, 11:12 PM
trax95008
2006 XK Commander
A battery warmer will be your best and only option
trax95008 is offline
post #4 of 19 Old 11-12-2012, 06:58 AM
suzieque
2008 WK
I wonder if a dual battery setup would be the best option if you don't have access to ac power for a battery warmer. You would have to modify the tray to hold 2 batteries or move the batteries to the passenger compartment.
I'm also looking for a new battery and thinking that 900 cold cranking amps is what I need for my diesel. I also saw a lithium ion car battery used on one of those automotive tv shows, I wonder if those would hold up to the extreme cold you are talking up.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #5 of 19 Old 11-12-2012, 08:29 AM
tjkj2002
2002 KJ Liberty
Lithium Ion batteries loose alot of power in extreme cold temps,much more then lead/acid batteries by far.You do not really want the batteries in the passenger cabin without the correct batteries used that have a vent port you can attach a hose to so you can route it outside the cabin.All batteries vent to some degree and it's some nasty stuff you don't want to breath in.
I'd try the Odyssey batteries for extreme cold,expensive but they are worth it.Totally skip over optima's,there junk now.
tjkj2002 is offline
post #6 of 19 Old 11-12-2012, 08:39 AM
suzieque
2008 WK
Yeah I wonder about battery venting too, though I seem to remember reading that the battery for the new wk2 is actually located under the passenger seat, so interior venting must be possible.
suzieque is offline
post #7 of 19 Old 11-12-2012, 09:11 AM
Radcrd
2007 WK
I ended up getting the Everstart Maxx H8 battery from Walmart for $117 as I could not wait or shop around. The H8 battery is 1000 CA and 900 CCA. It was the most powerful one I could find that fits. My OE battery was also an H8 rated at 800 CCA.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #8 of 19 Old 11-12-2012, 09:29 AM
WhiteOut
WhiteOut's Avatar
Lol at battery warmer. Just get a good battery, make sure your chargin system is on good repair.
WhiteOut is offline
post #9 of 19 Old 11-12-2012, 09:46 AM
Luck06
2006 WK
Expecting a rough winter down there in FL are ya? lol
Silver '06 Laredo 3.7L
- 2" RC lift, 1.5" RC Spacers, 58643 MLL's, !Pinch Weld, Spyder Bull Bar, 130w KC Daylighters, Spyder LED Tails, Taillight Guards, Silverstar ZXE's, Interior LEDs, Kenwood 6" DVD/NAV, 12" Audiobahn Sub
Luck06 is offline
post #10 of 19 Old 11-12-2012, 10:12 AM
tjkj2002
2002 KJ Liberty
Those batteries,like Volvo's,have the battery vent that a hose attaches to and get's vented to the outside of the cabin.
tjkj2002 is offline
post #11 of 19 Old 11-12-2012, 10:13 AM
suzieque
2008 WK
interesting. I had bought a walmart battery for my car and it has lasted a long time. I was going to buy a canadian tire battery for my jeep, but maybe i will look at the walmart one too, though the CCA on the walmart website says 760?
Features
108 Months Manufacturer's Warranty
36 Months Roadside Assistance
36 Months Free Replacement
760 CCA
Specifications
Country of Origin (assembly): USA
http://www.walmart.ca/en/ip/everstar...Box=&addFacet=
suzieque is offline
post #12 of 19 Old 11-12-2012, 10:56 AM
JRLT
2010 WK
Do you have a battery blanket?
http://www.justforjeeps.com/batteryblanket.html
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #13 of 19 Old 11-12-2012, 11:23 AM
Radcrd
2007 WK
Features
760 CCA
Specifications
The Website is WRONG! I thought so too and was going to get the 94R, then decided to look at the H8 which is same price but higher amps. Go check it out, maybe different provinces are getting different batteries from different suppliers??
3 VW TDI's (sold)
Radcrd is offline
post #14 of 19 Old 11-12-2012, 11:41 AM
suzieque
2008 WK
thanks, I will ask to look at the battery.
suzieque is offline
post #15 of 19 Old 11-13-2012, 02:29 AM
blizzboy283
2005 WK
I thought the same thing when I first read this thread.
OP, since its been brought up now...Are you moving to the artic, from FL?
05 WK LTD 5.7L Hemi QD II Midnight Blue Pearl, Blue WK Club member #30
Intune, AFE Stage 2 CAI, BT Catch Can, Gibson Cat-back, OME HD, 255/75/17 BFG KM1s, 1.25" Spidertrax, LED Interior, Reverse & Tail Lights, 3/4" Grille, Chrome Fuel Door & handles, SRT8 Pedals, Taylor Shorties, XK knob, 4xGuard Front 4 & Rear Diff.
blizzboy283 is offline
