What is It? - JeepForum.com
 1Likes
  • 1 Post By caddydaddy
post #1 of 8 Old 09-22-2017, 06:47 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
What is It?
Ok, CRD guys. I noticed this loose hose today on the driver's side of the engine compartment. It seems to lead down to a point on top of the transmission and it has a little green cap on it that fits loosely and wobbles around. I'm thinking it is a vent pipe of some kind.
What is it? Where does it attache. Notice in the picture that it has come loose from where ever it was attached.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #2 of 8 Old 09-22-2017, 06:58 PM
suctoes
I think that is either your transfer case vent or your evap system vent.
suctoes is online now
post #3 of 8 Old 09-23-2017, 07:17 AM
08CanuckCRD
2008 WK
I can't label the hose for you, Chirpz, but I've looked at it a couple of times in my engine bay and wondered about it, too.
2008 WK Grand Cherokee Limited 3.0L CRD TurboDiesel, QDII, Stock 245/60R18
08CanuckCRD is offline
post #4 of 8 Old 09-23-2017, 08:55 AM
caddydaddy
2007 WK
Thatís the transmission vent hose. The vent hose for the front diff is mounted to one of the studs for the passenger side strut mount. For some reason, the trans vent hose on mine was also just flopping around in there.
badgerwithhands likes this.
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
200,000+ miles!
caddydaddy is offline
post #5 of 8 Old 09-23-2017, 10:56 AM
badgerwithhands
2007 WK
IIRC, it used to clip to the front bracket for the engine cover. But yes, it's for the transmission. The transfer case vent is rather short.
07 WK Overland CRD, cargo LEDs, OME HD, MOPAR skids, rack,
future mods: tires, lights, CB, skids,
badgerwithhands is offline
post #6 of 8 Old 09-24-2017, 01:43 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Thanks for the comments. I still can't see where the little fastener plugs in, so I wire tied it to the engine cover mount.
Chirpz
Chirpz is offline
post #7 of 8 Old 09-25-2017, 03:12 AM
oilar
2005 WK
On my WK 2005 CRD there is some foam and a plastic cover over the 3 injectors. This cover has 2 points where the vent hose just is pushed down into to keep it in place.
oilar is offline
post #8 of 8 Old 09-26-2017, 10:02 AM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Ding Dong!! The light dawn. I bet mine was the same, but I removed and discarded those covers 60,000 miles ago.
Chirpz
Chirpz is offline
