Weird Problems Lately (Bad Key Message) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Weird Problems Lately (Bad Key Message)
*VOTE NOW Help Metalcloak Giveaway an XJ Suspension*TJ 5.25" Speaker Adapters - NalinMFGThe Original 3/8" Ruffstuff Diff Cover!
Unread 03-17-2014, 09:21 PM   #1
justinmiller930
2005 WK
Hello everyone! I wanted to get some opinions/solutions for a recent problem that I've been having. Let me give you some details on what's been going on with my 05 WK.
I was driving home the other day and noticed that my center stack lights were all out. None of the lights were on, but the radio and the buttons on the radio did work. I didn't really think much of it until it kept happening.
I also noticed that when the center stack lights are out, the tail lights also don't work (the brake lights do, but the running lights at night are not on). I also have aftermarket LED tail lights that I have had absolutely no problems with. Anyways..... In order to correct this, I simply turn off the key and then turn it back on. It usually corrects it.
The other day I got a message about a BAD KEY after I stopped for coffee in the morning. It started fine, but shut right off. The BAD KEY message came up. It also said that the key needs programmed. During this time it wouldn't let me start it. Not sure if these problems are related, but they just started happening.
Has this anyone happened to anyone else? Any quick suggestions before taking it to the dealership?
justinmiller930 is offline   Reply With Quote
Unread 03-17-2014, 09:31 PM   #2
Shafer57
2006 WK
Have you run a load test on the battery recently, if it hasn't been done, do that first. How old is the current battery?
Pep Boys, Advanced, they all do it free usually.
Next, i'd point the finger towards the ignition switch as it causes quite a few issues with these vehicles.
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline   Reply With Quote
Unread 03-17-2014, 11:41 PM   #3
justinmiller930
2005 WK
I had it tested a few months ago. They said it was okay.
Unread 03-18-2014, 06:30 AM   #4
Shafer57
2006 WK
The center console lights going out, that's what is throwing me off towards charge.
I'd start pointing the finger at the ignition switch next. Others will chime in i'm sure.
Unread 03-18-2014, 02:31 PM   #5
JKM
2005 WK
I would second the ignition switch, especially if you never replaced it on 2005 model year. They have updated/superseeded the part a number of times since 2005. Very common issue and I would start there.
JKM is offline   Reply With Quote
Unread 03-20-2014, 12:17 AM   #6
justinmiller930
2005 WK
It's been driving me crazy. If I simply turn the key off, and then start the car back up the lights will generally work.
What all is involved in replacing a starter switch?
Would an ignition/starter relay make it do this?
Unread 03-20-2014, 03:59 PM   #7
Shafer57
2006 WK
Not starter switch, ignition switch.
Write up- http://www.jeepforum.com/forum/f67/2...stall-1572769/
Unread 03-21-2014, 02:00 AM   #8
justinmiller930
2005 WK
Thanks for posting that, Shafer. The dealership quoted me $400-$500 to replace the ignition switch. If I could replace mine for under $50, I'm going to do it. I just hope that the problem doesn't get worse before it gets mailed to me and then I get time to put it in.
Did you replace your's?
Unread 03-21-2014, 06:21 AM   #9
Shafer57
2006 WK
I sold my truck before I fixed it.
You can call the dealer and ask for a price on the part itself, and do the job yourself? Give that a shot first.
