Water Pump maintenance? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Water Pump maintenance?
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Hey Guys - Extreme Terrain Jeep Outfitters - ExtremeTerraiThe Original 3/8" Ruffstuff Diff Cover!
Unread 03-09-2015, 08:23 PM   #1
BonesWK
BonesWK's Avatar
2006 WK
So my local trusted mechanic recommended new radiator hoses as well as a coolant fluid flush. My rig has 119k on it so I'm sure it's do for that since I've had it for 80k of that and it's never been done.
Question is, since they'll have it all drained should I have them change the water pump too? Or are these things a "run it til it breaks" item? I've just never seen it on a preventive maintenance post.
Ryan
2006 Black WK Limited 4.7 4x4 QD II
Lift/Tires/Stuff
If you want to achieve greatness, stop asking for permission
BonesWK is offline   Reply With Quote Quick reply to this message
Unread 03-10-2015, 02:12 AM   #2
JeepGreen07
2007 WK
Since your draining the coolant I'd replace it and the thermostat. Saves you going back and draining the coolant again when the water pump eventually fails. Just my thought.
2007 Jeep Grand Cherokee
Jeep Green Metallic
3.7L QT1
Stock 154000KM
JeepGreen07 is offline   Reply With Quote Quick reply to this message
Unread 03-10-2015, 06:42 AM   #3
caddydaddy
2007 WK
A water pump is a hit or miss with how long it will last. Some fail at 30k miles, some last 230k miles! I'd leave it alone unless you start hearing noise or seeing it weeping from the weep hole on the bottom of it.
If you're just going to replace parts just because they are old, that can get really expensive!
2007 CRD Grand Cherokee Limited 4x4
GDE ECO Tune, Turbo Resonator Delete
172,000+ miles!
caddydaddy is offline   Reply With Quote Quick reply to this message
Unread 03-10-2015, 07:19 AM   #4
paroxysym
2007 WK
id run it till it takes a dump... I think the coolant change and new hoses will only extend the life of the pump.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline   Reply With Quote Quick reply to this message
Unread 03-10-2015, 08:52 AM   #5
Morris4x4Center
Vendor
Morris4x4Center's Avatar
1987 YJ Wrangler
I'm here in Florida, personally I flush my coolant system every year or two. I'm a firm believer in flushing fluids (and changes, oil, trans, etc). often to avoid an issues. Coolant / Antifreeze degrades. and they normally have something to lubricate the water pump and so on. With the high temps here, it's brutal on fluids.
Just my 2 cents.
Morris4x4Center.com
Toll Free: 877.553.5337 | Free Shipping on Orders Over $99!|
PM us for any questions.
Morris4x4Center is offline   Reply With Quote Quick reply to this message
Unread 03-10-2015, 04:53 PM   #6
BonesWK
BonesWK's Avatar
2006 WK
Thanks for the replies guys I think I'll hold off on getting a pump for right now.
Ryan
Lift/Tires/Stuff
Unread 03-11-2015, 03:12 AM   #7
ggrassmid
Water Pump maintenance would have been great for me, but never heard of it before. WP on my CRD took a crap the other day. Walked out from store and had coolant all over the ground. Lucky/unluckly I was not far from dealer and a trip there, 3-days later, and a $840 bill and it was replaced. $57 for serp belt, $445 for pump and $270 for labor; my parts are discounted, normal price for pump would be $637 and belt $82.20.
Black 2008 Limited CRD
GDE EcoTune, EHM, 2014 Rubicon take-offs
JF Black WK Club #168
ggrassmid is offline   Reply With Quote Quick reply to this message
Unread 03-11-2015, 09:23 AM   #8
Morris4x4Center
Vendor
1987 YJ Wrangler
$445 for pump
What kind of pump was that? What size engine?
Just curious. :-)
Water pumps, by the way, eventually, will go bad on just about any vehicle.
So you're definitely not alone there :-)
Morris4x4Center.com
Unread 03-11-2015, 09:31 AM   #9
BonesWK
BonesWK's Avatar
2006 WK
A water pump from advanced is about 150 bucks for your CRD im a bit lost as well at the $450 price tag
Ryan
Lift/Tires/Stuff
Unread 03-11-2015, 09:31 AM   #10
caddydaddy
2007 WK
Originally Posted by Morris4x4Center View Post
$445 for pump
Just curious.
I'd guess it was a Mopar pump. And since it was a CRD, it probably came from Mercedes. That price sounds about right for that.
Unread 03-12-2015, 07:36 AM   #11
Morris4x4Center
Vendor
1987 YJ Wrangler
Water Pump
Ah, I see, thank you :-)
Morris4x4Center.com
