Water leak inside truck during rain - Page 2 - JeepForum.com
post #16 of 29 Old 07-30-2012, 06:59 AM
TurboDiesel
2008 WK
that doesnt help with the rear drains tho
the front u can also see where it ends under the vehicle
the rear u cant see from underneathe
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #17 of 29 Old 07-30-2012, 07:13 AM
mrnavy2
2008 XK Commander
There are Drain Hoses in the rear of the Sun Roof?
mrnavy2 is offline
post #18 of 29 Old 07-30-2012, 12:05 PM
marko138
2011 WK
Wow, just noticed a drip in the same spot on mine yesterday.
marko138 is offline
post #19 of 29 Old 07-30-2012, 08:08 PM
TurboDiesel
2008 WK
yep i got a whole thread of my sunroof problem
post #20 of 29 Old 07-30-2012, 08:35 PM
mrnavy2
2008 XK Commander
Send me the link please.
mrnavy2 is offline
post #21 of 29 Old 07-30-2012, 10:30 PM
TurboDiesel
2008 WK
http://www.jeepforum.com/forum/f67/roof-leak-1332284/
post #22 of 29 Old 08-01-2012, 12:05 PM
marko138
2011 WK
Mine was clogged. It's no longer clogged. Easy fix!
marko138 is offline
post #23 of 29 Old 08-06-2012, 06:00 PM
ccsicecoke
2006 WK
seems a common issue
ccsicecoke is offline
post #24 of 29 Old 08-08-2012, 10:10 PM
lambo05grand
Mine leaks out of the same top flap above the "oh crap" handle, however, I don't have a sunroof? This drain you guys are referring to, could this be my issue as well?
lambo05grand is offline
post #25 of 29 Old 08-08-2012, 10:27 PM
Chirpz
Chirpz's Avatar
2007 WK
No, your prime suspect would be the roof luggage rack. Remove the rack and reseal the holes. Go to a glass show and get about a foot of their thinnest Butyl Tape. Place a strip over each hole. Poke a small hole in the center of the strips and replace the bolts allowing the butyl tape to work into the hole. You do not have to completely remove the rack... do one attachment at a time and just lift it up to have working room. Prop it up with a block or whatever while you work on the hole.
This beats teflon tape or silicone or both.
Also check the corner of your windshield for a tiny leak in the body seam. You can see the tiny seam if you remove the column covers and use a light and a mirror. Mine leaked there.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #26 of 29 Old 09-18-2012, 03:50 PM
lambo05grand
Chirpz, what do you mean a glass show? Is the butyl tape, or an equivalent, something that a Lowes would carry? I'm fairly certain it is indeed the roof rack because if I park on a slight incline there is no leak (the incline is not enough to where it would not leak in the corner of the windshield). Although its probably leaking into the rear of the cab somehow lol, at least not on my leg!
post #27 of 29 Old 09-18-2012, 09:07 PM
Chirpz
Chirpz's Avatar
2007 WK
Sorry.... Typo.... I meant "glass shop." I worked at a glass shop. Most glass shops have butyl tape in a variety of types. You want something thin (1/16" or 1/8") and at least 1/2" wide. Wider is better. I used a type that has a foil backing. You can actually iron it on if you like. It is ideal but hard to find.
Chirpz
Chirpz is offline
post #28 of 29 Old 09-19-2012, 08:39 AM
marko138
2011 WK
A quick follow up...
It absolutely POURED here yesterday. No leaks from mine!
marko138 is offline
post #29 of 29 Old 09-19-2012, 10:04 AM
partlowr
2007 WK
Originally Posted by Chirpz View Post
I had a similar leak on the driver side, but in my case it was not the drain tube, it was a tiny body seam that is located at the top corner of the windshield. You can see it with a flashlight and mirror from inside after you remove the column.
I poured gallons of water down my drain tubes looking for leak and it never showed up. Here is my thread on the subject and how I fixed it.
http://www.jeepforum.com/forum/f67/r...-roof-1232897/
I have had the same annoying leak on the drivers side grab bar ever since I purchased mine new in 2007, it leaked on the two days after I purchased it brought it back to dealership 3 times and they have never been able to fix it. I will check out the link you provided.
partlowr is offline
leak , rain , water
Rain water getting inside? 02Lightning ZJ Grand Cherokee Forum 3 11-01-2010 06:56 PM
Rain water on ZJ driver's floorboard TX98ZJ ZJ Grand Cherokee Forum 5 01-18-2010 02:00 PM
Hard Rain = Water in Roof. Help? NightbaneZ24 ZJ Grand Cherokee Forum 4 12-26-2009 11:30 AM
WJ big leak in cargo after rain steveadam87 ZJ Grand Cherokee Forum 4 07-24-2008 11:19 PM
96 ZJ with a leak. Not an engine leak, an inside leak! gixxerjaker ZJ Grand Cherokee Forum 1 03-04-2008 04:58 PM
