Water leak inside truck during rain - JeepForum.com
post #1 of 29 Old 07-28-2012, 03:25 PM Thread Starter
Shafer57
2006 WK
06' GC Limited Hemi.
Leaking from the passenger side handle attached to windshield.
There are two tabs on the pillar and the top tab was leaking water all over during a very heavy rain storm. I'll be posting pictures soon to give an idea where the water was coming from incase you don't already know.
I looked outside and can see no visible body molding, or weather seal imperfections. Is there drain tubes through there where runoff water goes incase the vent is open on my sunroof?
Any help appreciated.
Dodge Dakota R/T 360ci Small-block _sold_
Jeep GC 5.7L Hemi- Magnaflow Cat-Back, BT Catch Can, 20" Gloss black SRT Reps
275/45R20 Nexen Roadian, Blacked out, 180 Stat _SOLD_
2008 335i Twin-Turbo
Shafer57 is offline
post #2 of 29 Old 07-28-2012, 04:16 PM
kllshadow
2006 WK
Sun roof drain is leaking. Not sure how to fix it but someone will chime in.
Sent from my EVO using JeepForum
Black WK Club Member #61
kllshadow is offline
post #3 of 29 Old 07-28-2012, 05:09 PM
TurboDiesel
2008 WK
i went to the dealer to get mine fixed after 6 attempts myself...
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #4 of 29 Old 07-28-2012, 07:11 PM
mrnavy2
2008 XK Commander
Do a search on sun roof leaks n it will tell u how to repair the drain hose from the sun roof. Very easy fix. There is even a YouTube how to fix the drain hose.
mrnavy2 is offline
post #5 of 29 Old 07-28-2012, 09:58 PM
kllshadow
2006 WK
If.you get one of those cans of compressed air and shoot it down the tube it would probably work.
post #6 of 29 Old 07-28-2012, 10:17 PM
Chirpz
Chirpz's Avatar
2007 WK
I had a similar leak on the driver side, but in my case it was not the drain tube, it was a tiny body seam that is located at the top corner of the windshield. You can see it with a flashlight and mirror from inside after you remove the column.
I poured gallons of water down my drain tubes looking for leak and it never showed up. Here is my thread on the subject and how I fixed it.
http://www.jeepforum.com/forum/f67/r...-roof-1232897/
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline
post #7 of 29 Old 07-29-2012, 12:54 AM
Slivs18
2008 WK
Had the same problem on the drivers side, sounds like the sun roof drain. If you use power air be careful you don't blow the clamp off and destroy your drain all together.
2008 Silver WK Grand Cherokee/ 3.7L/ Weather Tech Mats (Both Rows and Cargo)/ Flowmaster 40 Series Delta Flow/ K & N 77 Series CAI/
Slivs18 is offline
post #8 of 29 Old 07-29-2012, 08:44 AM Thread Starter
Shafer57
2006 WK
Sounds like im we're on the right track. Thanks alot, and i'll be updating as soon as possible.
Shafer57 is offline
post #9 of 29 Old 07-29-2012, 11:06 AM
Theogriff15
2006 WK
Funny story I had the same problem last night on my drivers side. I kept feeling a drip on my left leg. I havent looked at the pillar yet and I don't rly know how to go about doing so but I'm gona give it a try this afternoon.
2006 - 3.7L, Superlift, 265 Guard Dogs, 30" LED Bar, Bilsteins, Spidertraxx, Solid, Hypertech, Rola, Rear Led, Led Tails, S4xC Skids
Theogriff15 is offline
post #10 of 29 Old 07-29-2012, 12:58 PM
TurboDiesel
2008 WK
does it tell u how to do it on our jeeps?
i never found a video when i was having my problem
post #11 of 29 Old 07-29-2012, 01:06 PM
mrnavy2
2008 XK Commander
Yes it does. I wish I wad on my pc now so I could attach it for you. But once u fine the video u will be surprise how easy it is.
mrnavy2 is offline
post #12 of 29 Old 07-29-2012, 01:23 PM
RichardZ
2006 WK
Have a 2006 Grand Cherokee with the same problem. Once in a long while I'll get a drip on my left leg, only happens when I get in the auto to start it. I've also had it drip from the small plastic access covers on the A-column (not sure what those covers are for ?). I'd like to know how to get to the sunroof drainage tube - I couldn't see it looking in the front of the sunroof opening. Does it stick out the bottom of the bodywork ?
RichardZ is offline
post #13 of 29 Old 07-29-2012, 10:08 PM
TurboDiesel
2008 WK
hmm i may just have to look again
dealership replaced my drain tube for $120 i think so it wasnt too bad
wish i knew how to do it myself...guess ima go on a google hunt lol
post #14 of 29 Old 07-30-2012, 05:32 AM
mrnavy2
2008 XK Commander
Go to YouTube and do a search for Jeep Commander Sunroof Leak. You should fine something there.
mrnavy2 is offline
post #15 of 29 Old 07-30-2012, 07:30 AM
mrnavy2
2008 XK Commander
Check out this link.. I hope that this helps.. Steve
mrnavy2 is offline
leak , rain , water
Rain water getting inside? 02Lightning ZJ Grand Cherokee Forum 3 11-01-2010 07:56 PM
Rain water on ZJ driver's floorboard TX98ZJ ZJ Grand Cherokee Forum 5 01-18-2010 03:00 PM
Hard Rain = Water in Roof. Help? NightbaneZ24 ZJ Grand Cherokee Forum 4 12-26-2009 12:30 PM
WJ big leak in cargo after rain steveadam87 ZJ Grand Cherokee Forum 4 07-25-2008 12:19 AM
96 ZJ with a leak. Not an engine leak, an inside leak! gixxerjaker ZJ Grand Cherokee Forum 1 03-04-2008 05:58 PM
