-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   Water leak inside truck during rain (http://www.jeepforum.com/forum/f67/water-leak-inside-truck-during-rain-1398677/)
Shafer57 07-28-2012 02:25 PM
06' GC Limited Hemi.
Leaking from the passenger side handle attached to windshield.
There are two tabs on the pillar and the top tab was leaking water all over during a very heavy rain storm. I'll be posting pictures soon to give an idea where the water was coming from incase you don't already know.
I looked outside and can see no visible body molding, or weather seal imperfections. Is there drain tubes through there where runoff water goes incase the vent is open on my sunroof?
Any help appreciated.
kllshadow 07-28-2012 03:16 PM
Sun roof drain is leaking. Not sure how to fix it but someone will chime in.
Sent from my EVO using JeepForum
TurboDiesel 07-28-2012 04:09 PM
i went to the dealer to get mine fixed after 6 attempts myself...
mrnavy2 07-28-2012 06:11 PM
Do a search on sun roof leaks n it will tell u how to repair the drain hose from the sun roof. Very easy fix. There is even a YouTube how to fix the drain hose.
kllshadow 07-28-2012 08:58 PM
If.you get one of those cans of compressed air and shoot it down the tube it would probably work.
Chirpz 07-28-2012 09:17 PM
I had a similar leak on the driver side, but in my case it was not the drain tube, it was a tiny body seam that is located at the top corner of the windshield. You can see it with a flashlight and mirror from inside after you remove the column.
I poured gallons of water down my drain tubes looking for leak and it never showed up. Here is my thread on the subject and how I fixed it.
http://www.jeepforum.com/forum/f67/r...-roof-1232897/
Slivs18 07-28-2012 11:54 PM
Had the same problem on the drivers side, sounds like the sun roof drain. If you use power air be careful you don't blow the clamp off and destroy your drain all together.
Shafer57 07-29-2012 07:44 AM
Sounds like im we're on the right track. Thanks alot, and i'll be updating as soon as possible.
Theogriff15 07-29-2012 10:06 AM
Funny story I had the same problem last night on my drivers side. I kept feeling a drip on my left leg. I havent looked at the pillar yet and I don't rly know how to go about doing so but I'm gona give it a try this afternoon.
TurboDiesel 07-29-2012 11:58 AM
does it tell u how to do it on our jeeps?
i never found a video when i was having my problem
mrnavy2 07-29-2012 12:06 PM
Yes it does. I wish I wad on my pc now so I could attach it for you. But once u fine the video u will be surprise how easy it is.
RichardZ 07-29-2012 12:23 PM
Have a 2006 Grand Cherokee with the same problem. Once in a long while I'll get a drip on my left leg, only happens when I get in the auto to start it. I've also had it drip from the small plastic access covers on the A-column (not sure what those covers are for ?). I'd like to know how to get to the sunroof drainage tube - I couldn't see it looking in the front of the sunroof opening. Does it stick out the bottom of the bodywork ?
TurboDiesel 07-29-2012 09:08 PM
hmm i may just have to look again
dealership replaced my drain tube for $120 i think so it wasnt too bad
wish i knew how to do it myself...guess ima go on a google hunt lol
mrnavy2 07-30-2012 04:32 AM
Go to YouTube and do a search for Jeep Commander Sunroof Leak. You should fine something there.
mrnavy2 07-30-2012 06:30 AM
Check out this link.. I hope that this helps.. Steve
The time now is 06:11 AM.
