Water leak - JeepForum.com
post #1 of 3 Old 04-11-2013, 04:24 PM Thread Starter
brnelam
Water leak
just noticed that the passanger front carpet and under the carpet is soaking wet on my 2005 grand cherokee, anyone got any ideas where it might be comming from, it seems to be clean water.
cheers
brnelam is offline
post #2 of 3 Old 04-11-2013, 04:35 PM
gamma500
2015 WK
I believe this associated with the A/C evap. box drain tube being plugged...do a Search on YouTube and ,I believe, there is a video showing a DIY fix...involves accessing and drilling hole in plastic area where drain starts. Video shows water gushing forth when drill bit enters and then shows subsequent cleaning on tube with compressed air or wire plunger. Here you go, mate, I think this is it.
http://youtu.be/DTi1-i4GRqY
gamma500 is offline
post #3 of 3 Old 04-18-2013, 02:44 PM
darot
Also check your heater core, could be the start of wonderful things....
There is a short cut to replacing the heatercore.
darot is offline
