Washer pump electrical connector removal - JeepForum.com
post #1 of 4 Old 09-19-2013, 09:00 PM Thread Starter
ptdancer
2005 WK
Replacing the pump on 05 grand cherokee, am stumped by the challenge of disconnecting the connector from the top of the pump assembly. I did my due diligence and search this forum and others but no luck. Does anyone have a good instruction as to how to remove this connector? What is the trick I'm missing? Thanks.
ptdancer is offline
post #2 of 4 Old 09-19-2013, 09:24 PM
816jared
2005 WK
are your windshield wiper squirts not working?
this is something I need to address soon as well, more annoying than anything else
816jared is offline
post #3 of 4 Old 09-30-2013, 02:47 PM
afhanson72
Did you figure this out yet?
I am going home tonight to replace my washer pump. I have not looked at the connector yet, but it may have a slide tab that you need to slide up with a small screw driver in order to disconnect the plug. Otherwise, I can only imagine you might need to depress the locking tab with a small screw driver?
Al
94 YJ - Plenty of mods
afhanson72 is offline
post #4 of 4 Old 09-30-2013, 07:08 PM
afhanson72
It is as I suspected....a red tab you slide up, then push I on the black tab and it will come undone
Al
