Warranty Question - JeepForum.com
post #1 of 9 Old 10-31-2011, 10:21 AM Thread Starter
SamanthaAnn
2008 WK
Warranty Question
I'm not sure if anyone would know this question, but if I put a 2 inch lift and bigger tires on my Jeep will it void my warranty that I still have on it?
it's a 2008 Jeep Grand Cherokee Limited, if that helps any..
SamanthaAnn is offline
post #2 of 9 Old 10-31-2011, 10:55 AM
smcginnis87
4X4WK
smcginnis87's Avatar
2007 WK
Nope it should not.... I have never had a problem with that..
2015 WK2
--4x4WK--
smcginnis87 is offline
post #3 of 9 Old 10-31-2011, 11:19 AM
robpp
it DEPENDS...... THE LAW states if the dealer can prove that an aftermarket part caused another part to fail....then they dont have to cover it.
EX: you control arm bushes wear out the dealer MAY try to blame the lift. but lets say its a headlight they cant say the lift caused that.
i would prolly say that any driveline related part MAY not be covered due to the lift.
EACH DEALER will be different i n how they deal with this BUT the law is as i said above.
here read this: http://autos.aol.com/article/warrant...rmarket-parts/
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline
post #4 of 9 Old 10-31-2011, 11:44 AM Thread Starter
SamanthaAnn
2008 WK
Great, thanks !
post #5 of 9 Old 10-31-2011, 11:48 AM Thread Starter
SamanthaAnn
2008 WK
another question for you, because you have a hemi .. is it safe to use a performance chip with a hemi..does that have any effect on that type of motor. All I'm looking to do is save gas milage but i guess i should of thought about that before i choose the hemi, but i had to have it. I'm just trying to see if there's anything out there that would save me a few mpg's.
post #6 of 9 Old 10-31-2011, 12:17 PM
suzieque
2008 WK
there was a thread about a jk owner being put on the "warranty null and void" list due to a lift and tires. I will try and find that thread, a very interesting read as he fought to get his warranty re-instated.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #7 of 9 Old 10-31-2011, 07:27 PM
smcginnis87
4X4WK
2007 WK
Yea its fine I have the superchips programmer, I have only changed my tire size with it.
2015 WK2
--4x4WK--
post #8 of 9 Old 11-01-2011, 07:58 AM
suzieque
2008 WK
here is the thread I was referring to
http://www.jeepforum.com/forum/f67/i...ssues-1216516/
this thread in turn points you to a JK forum where an owner had an issue with a dealer after a lift and tires were installed. The JK forum is a long read, but worth it if you really want to hear a person's experience. Worth noting that other manufacturers take the same position as Chrysler when it comes to mods and warranty.
I would say you should be prepared to lose any warranty claims against suspension components (tie rods, ball joints) and maybe even drive shafts and transfer cases after installing a lift and larger than stock wheels/tires.
suzieque is offline
post #9 of 9 Old 11-06-2011, 02:01 PM Thread Starter
SamanthaAnn
2008 WK
Okay great, thanks
lift , warranty questions
warranty question mlm0 ZJ Grand Cherokee Forum 2 11-22-2008 07:32 PM
Factory Warranty/Extended Warranty work by non Chrysler dealership? sierra4me WK Grand Cherokee & XK Commander Forum 2 10-07-2008 10:52 PM
Warranty Question brsox88 ZJ Grand Cherokee Forum 10 11-07-2007 05:24 PM
Warranty question adstroop WK Grand Cherokee & XK Commander Forum 3 10-06-2007 02:11 PM
Question about 7/70 warranty reneveah ZJ Grand Cherokee Forum 4 06-01-2006 08:32 AM
