Warn Zeon Winches & Recessed Bumpers - JeepForum.com
post #1 of 17 Old 01-13-2014, 03:32 PM Thread Starter
ttusqrl
2005 WK
I figured I would start a thread for future reference in the WK section in case anyone runs into a similar situation I did.
I ended up putting a S4XC bumper on my WK, which obviously prompted me to buy a winch. I did a lot of research and decided on the Warn Zeon (specifically the 10s). Now, I knew that these were huge compared to other winches, but I don't think I full appreciated the size.
I test fit the winch to the bumper and the winch is roughly 1/4" too large for the recess. The end effect is that there is approximately a 3/8" gap between the winch feet and the winch plate. I did quite a bit of research on the topic and it looks like all of the JK guys are running into the same issue with their bumpers. There are a few options to cure this problem:
1.) Shave down the bumper (not recommended)
2.) Shave down the winch housing (I didn't want to do this)
3.) Put spacers in between the plate and the winch
I ended up going with option 3. This was first created by Poison Spider for their bumpers, and apparently all they needed was a 1/4" spacer to do the trick. For my instance, I needed 1/2" to be comfortable. I found billet aluminum spacers from ACE and they are currently in the mail to me. One thing to note, you will also need longer hardware since the bolts are specifically sized and we are adding spacer depth to those. I'm sure it goes without saying, but make sure you get grade 8 hardware.
I'll take pictures and post on here once I finish the install. This is also necessary if you go with a powerplant or large winch other than the Zeon.
One other small issue for those who end up with a S4XC or Aspen Creek bumper in their possession -- FOLLOW THE INSTRUCTIONS WHEN IT SAYS TO MOUNT YOUR WINCH. I ignored these since I didn't have everything ready for mine. I ended up mounting the bumper and now I have no clue how I am going to put the winch on short of taking the bumper back off (which I really don't want to do).
More info to come.
2005 WK 5.7 ORT | Mod SL (OME struts & 990s) | JBA UCAs & Discos | Saguaro Front Bumper | Warn Zeon 10s | 285/70/17 BFG TA KO | AIRAID CAI | Gibson 3" Exhaust | DiabloSport Intune | JL Stealthbox
ttusqrl is offline
post #2 of 17 Old 01-14-2014, 05:53 PM
Tango.
2008 WK
and... when you need to replace the winch motor bushings then you will again need to R&R the bumper.
Tango. is offline
post #3 of 17 Old 02-03-2014, 06:28 AM Thread Starter
ttusqrl
2005 WK
Alright, so a quick update to this topic with some lessons learned. I've installed the Zeon with the ACE spacers which required 45 mm bolts to adjust for the added length. The fit is perfect with these for the Saguaro (S4XC) and Aspen Creek bumpers, but you might be able to swing a smaller spacer if you have a different bumper with a shorter recess.
The longer bolts created a different issue though -- they wouldn't fit through the winch plate holes straight up and down. I ended up putting two access points in the bumper with a plasma cutter and repaired the open surface with some satin black + primer in a rattle can. These hide perfectly behind the license plate so they are not an eye sore.
I'll include pics in the next post from my phone for reference. I would say that there is no way you would want this winch for hidden winch applications because it flat out won't fit. This was a longer than expected journey for me, but hopefully this helps someone else if they wind up going down this path.
ttusqrl is offline
post #4 of 17 Old 02-03-2014, 06:30 AM Thread Starter
ttusqrl
2005 WK
ttusqrl is offline
post #5 of 17 Old 02-03-2014, 07:24 PM
Valpacer
2007 WK
Those cutouts are interesting, my Saguaro bumper has the area behind the plate already removed, and bolting the winch down was no issue on the Jeep. Have changed winches twice without removing the bumper.
And yes those winches are massive!
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries -
Valpacer is offline
post #6 of 17 Old 02-03-2014, 08:44 PM Thread Starter
ttusqrl
2005 WK
Mind snapping some pics Valpacer? Id be interested in seeing your setup.
ttusqrl is offline
post #7 of 17 Old 02-03-2014, 10:40 PM
Valpacer
2007 WK
You can see the cutouts in this one, i have a camera mounted in the cutout as well.
Valpacer is offline
post #8 of 17 Old 02-03-2014, 10:50 PM Thread Starter
ttusqrl
2005 WK
Interesting! Mine definitely did not have them as you can tell from the pic. Wonder if mine was an earlier generation.
Thanks for the pic Val
ttusqrl is offline
post #9 of 17 Old 02-03-2014, 11:02 PM
sickchilly
2010 WK
ttusqrl - you have an earlier generation, maybe even an early prototype or first run. When I was discussing winch selection with Ken, he specifically recommended the Zeon and said it can be installed after the bumper is mounted. He said the only winches that (probably) wouldn't fit are the older 827x upright series and the Powerplant.
2010 Brilliant Black Crystal Pearl Coat Grand Cherokee S-Limited with various bits 'n pieces... broken in but not even finished!
sickchilly is offline
post #10 of 17 Old 02-03-2014, 11:27 PM
Valpacer
2007 WK
Im pretty sure mine and the first lot sent to Australia were setup for Aussie size plates and the cutouts were asked for by Stu when he ordered them, memories coming back slowly! lol
Valpacer is offline
post #11 of 17 Old 02-03-2014, 11:29 PM
Valpacer
2007 WK
I cant run my plate in the spot it is supposed to anyway, our police dont like then angle it on, apparently it cant be picked up by the speed cameras......:-)
So i just ziptie it through the fairlead and pull it off for wheeling
Valpacer is offline
post #12 of 17 Old 02-04-2014, 05:48 AM Thread Starter
ttusqrl
2005 WK
Can you measure your recession width and depth wise when you get a chance?
ttusqrl is offline
post #13 of 17 Old 02-04-2014, 08:20 PM
ducktail
2009 WK
What bumper is that?
2009 GC Limited. 265 70 18 is the only change to date. Bought some Rubicon 17" wheels and put BFG M/T's on for hunting season OME HD Front, OME MD rear, winch to come, basket and lights bars first
ducktail is offline
post #14 of 17 Old 02-04-2014, 09:28 PM
sickchilly
2010 WK
Originally Posted by ttusqrl
Can you measure your recession width and depth wise when you get a chance? Sent from my iPhone using JeepForum
Mine measures 25"L x 8.5"W x 2.375"D. That's just the flat tray part. There is an additional 2.5" on either side, but that's where the front starts curving in and the bottom angles up slightly.
It has a ton of mounting holes and plenty of access to mount the winch with the bumper on.
post #15 of 17 Old 02-05-2014, 09:04 AM Thread Starter
ttusqrl
2005 WK
Yep, your AC one is definitely different than my S4XC. I have 4 mounting holes and a much smaller tray.
Good to know -- thanks for the pic!
When does yours get put on?
ttusqrl is offline
