wanting a 3" lift on 05 JGC - JeepForum.com
post #1 of 9 Old 07-26-2012, 11:55 AM Thread Starter
countrydeluxe05
What is the best 3 inch lift that's not real expensive?
countrydeluxe05 is offline
post #2 of 9 Old 07-26-2012, 12:16 PM
kllshadow
2006 WK
OME will be the best for around 3in. PM Kolak he will get you the best price. I'm guessing it would be between $700-800. If you want to spend less you can go with a BB like Rough country which is a spacer lift.
Black WK Club Member #61
kllshadow is offline
post #3 of 9 Old 07-26-2012, 12:55 PM
paroxysym
2007 WK
OME HD will be closer to $800 shipped and is probably the best option as it replaces the coils/shocks. now if youre looking to spend a couple hundred less- get yourself a RRO 2.5" BB and some bilstein HDs, or go RC 2" BB with Bilstein HDs in the front with a rustys strut spacer and some monroe load levelers in the rear... one of those combos will be get you between 2.5"-3" of lift and great improve the ride. ranging from $500-$800.
being that its an 05 and 'pending your mileage, while youre in there look at replacing your coil spring isolators for alittle boost.
2007.5 WK Laredo 4.7
OEM+
paroxysym is offline
post #4 of 9 Old 07-26-2012, 01:52 PM
trax95008
2006 XK Commander
If your shocks/struts are in decent shape, (already replaced) you can get just the OME springs. I'm just specifying that they are sold separately and not as a "package"
trax95008 is offline
post #5 of 9 Old 07-26-2012, 01:59 PM
paroxysym
2007 WK
he will need at least rear shocks, as the stock shocks arent long enough to acommodate the additional length with the OME HD kit
OEM+
post #6 of 9 Old 07-26-2012, 02:04 PM
dtownmil
Sorry, Just realized yours is not a WJ. Not sure for your model year what kit is best.
I've been researching the IRO 3" kit, and for $499, seems like a great kit. Gets good reviews. http://www.ironrockoffroad.com/Merchant2/merchant.mvc?
I'm about ready to order this kit.
dtownmil is offline
post #7 of 9 Old 07-26-2012, 02:54 PM
Kolak
Vendor
Kolak's Avatar
The OME HD kit would be the best way to achieve 3" of lift on the WK. I do have it on special right now so PM me if you'd like a price. If that's not in the budget, I'd suggest a 2" Budget Boost kit and some good struts and shocks such as Bilstein.
Kolak Performance and Offroad
Member: Specialty Equipment Market Association
Telephone: 480 998-3661
or
Kolak is offline
post #8 of 9 Old 07-26-2012, 11:01 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
The question you need to ask is what is the most appropriate lift for your application. You could ask "what is the best lift" to 10 people on here and get 10 different answers with 10 different reasons. I'm not trying to be an @$$ I'm just saying the "best" is a matter of opinion and function. There are several ways to get 2"-3" of lift (as is mentioned above) and they all have their pros and cons. That being said - I went with the OME HD which yielded me a solid 3" of lift. The pros - replaces all the spring coils, both shocks, both struts, handles great on the road, does amazing on the trails. The cons - aside from the Superlift, it is one of the more costly lifts for the WK platform.
Give these 3 stickied threads a look. They will be invaluable in your quest for the set-up that fits whatever you're looking for:
http://www.jeepforum.com/forum/f67/w...thread-318023/
http://www.jeepforum.com/forum/f67/w...hread-1246013/
http://www.jeepforum.com/forum/f67/w...-list-1163371/
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #9 of 9 Old 07-27-2012, 04:52 AM
Luck06
2006 WK
Do you have a V6 or V8? If you have a V6 you should be able to get about 3" higher than most of the stock V8 guys with just a 2" RC lift and some F150 MLLs, which in my case only cost me $200. You can't get much more inexpensive than that. Don't forget that no matter which lift you go with, you'll most likely want to do spacers (or different wheels) and bigger tires so there's another $700 at least.
Silver '06 Laredo 3.7L
- 2" RC lift, 1.5" RC Spacers, 58643 MLL's, !Pinch Weld, Spyder Bull Bar, 130w KC Daylighters, Spyder LED Tails, Taillight Guards, Silverstar ZXE's, Interior LEDs, Kenwood 6" DVD/NAV, 12" Audiobahn Sub
Luck06 is offline
