W5J400/W5A580 swap - JeepForum.com
post #1 of 2 Old 07-31-2008, 01:12 PM Thread Starter
W5J400/W5A580 swap
If this is possible, I'd like to build this thread for reference and maybe a sticky. With the ease of adding torque to the already torquey 3.0 a 400 maximum torque input seems shallow.
Can this be done? -Bell housing/FCM/TCM/ECU Flash?
---- is offline
post #2 of 2 Old 07-31-2008, 06:28 PM
Mish_Mish
Mish_Mish's Avatar
2008 WK
Are you sure 580 has higher torque rating?
How about helping me replace ring and pinions to ~3.45 to drop freeway rpm 400 rpm, or so? How do I change axle ratios in transmission control box, if needed?
06 Touareg V10 TDi
Mish_Mish is offline
ZJ tie rod swap from 4.0 to 5.2 is it possible? bigals28xj ZJ Grand Cherokee Forum 5 07-14-2010 11:26 AM
doing 247/242 swap....need advice on front output shaft swap.. krazyteggy ZJ Grand Cherokee Forum 5 12-30-2009 07:44 PM
changing trans fluid on W5A580 stgry1 WK Grand Cherokee & XK Commander Forum 60 11-16-2008 07:56 PM
91 -97 Tcase Swap or motor swap ezrider327 ZJ Grand Cherokee Forum 6 05-12-2008 12:47 PM
NP 249 NP 242 Swap 94 ZJ 5.2 Trans Case swap / repair? smkarner ZJ Grand Cherokee Forum 1 09-27-2005 06:28 PM
