W5A580 leaking, not sure where though... - JeepForum.com
post #1 of 6 Old 09-01-2012, 03:56 AM Thread Starter
talkboxier
2006 WK
So I have a 2006 grand cherokee laredo with a w5a580 tranny, and it has a really bad leak which seems to be coming from the front passenger side of the oil pan... I read some forums saying that it could be the connector bushing, so I decided to do a little test.
I wiped everything down clean, took off the metal guard that was protecting it, and then wrapped a white cloth around it. I then drove it for a bit to check where the leak was coming from. Crawled under the car to check, and the cloth was dry. But the pan was dripping.
Is there any other places I should be checking for common leaks?
Thanks
talkboxier is offline
post #2 of 6 Old 09-01-2012, 11:43 AM
Piepenbrok420
Thanks
Yea, check the pan gasket
Built Not Bought. 2013 JK trailrig. Instagram: @chrispiepenbrok
Piepenbrok420 is offline
post #3 of 6 Old 09-01-2012, 01:00 PM Thread Starter
talkboxier
2006 WK
I checked it, and actually replaced the gasket and the filter not to long ago. I thought that was the issue at first...
post #4 of 6 Old 09-02-2012, 06:10 PM
Piepenbrok420
Put some UV leak detection dye from any local parts store in the trans. Clean the undercarriage, drive it a day, then take any UV light under there and you'll see where its coming from.
post #5 of 6 Old 09-02-2012, 07:09 PM
84foxgt
2007 WK
check the harness that goes into the trans on the pass side. there is a small metal shield that covers it. once removed you will see the harness. it uses a plug "adapter" that has orings on it. they were redesigned because of this problem. it costs $7-$10 at the dealer. very common problem.
2007 v6: Rough Country kit, Aries taillight gaurds, 2457517 Wrangler Silent Armors, LED interior lights, painted oe wheels Gunmetal, Topline 1.5" wheel spacers,SOLID rear diff cover,CREE backup lights,Hypertech Programmer
84foxgt is offline
post #6 of 6 Old 09-03-2012, 02:30 AM Thread Starter
talkboxier
2006 WK
@84foxgt
I am ordered the the bushing with the new o-rings already, but I live in hawaii. I don't think I can wait much longer for it so I am gonna head to my nearest dealership and see if they have any.
@Piepenbrok420
that sounds like an awesome idea!!!
thanks guys, gonna try those and and post my results.
fluid , leak , transmission
Dependability W5A580 Automatic Tranny stryker221982 WK Grand Cherokee & XK Commander Forum 10 03-01-2011 06:34 AM
automatic transmission (W5A580) urezki WK Grand Cherokee & XK Commander Forum 8 04-13-2010 11:36 AM
changing trans fluid on W5A580 stgry1 WK Grand Cherokee & XK Commander Forum 60 11-16-2008 06:56 PM
W5J400/W5A580 swap ---- WK Grand Cherokee & XK Commander Forum 1 07-31-2008 05:28 PM
TC leaking jeepunlimited ZJ Grand Cherokee Forum 10 01-29-2007 08:12 AM
