-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   W5A580 leaking, not sure where though... (http://www.jeepforum.com/forum/f67/w5a580-leaking-not-sure-where-though-1412250/)
talkboxier 09-01-2012 04:56 AM
So I have a 2006 grand cherokee laredo with a w5a580 tranny, and it has a really bad leak which seems to be coming from the front passenger side of the oil pan... I read some forums saying that it could be the connector bushing, so I decided to do a little test.
I wiped everything down clean, took off the metal guard that was protecting it, and then wrapped a white cloth around it. I then drove it for a bit to check where the leak was coming from. Crawled under the car to check, and the cloth was dry. But the pan was dripping.
Is there any other places I should be checking for common leaks?
Thanks
Piepenbrok420 09-01-2012 12:43 PM
Thanks
Yea, check the pan gasket
talkboxier 09-01-2012 02:00 PM
I checked it, and actually replaced the gasket and the filter not to long ago. I thought that was the issue at first...:(
Piepenbrok420 09-02-2012 07:10 PM
Put some UV leak detection dye from any local parts store in the trans. Clean the undercarriage, drive it a day, then take any UV light under there and you'll see where its coming from.
84foxgt 09-02-2012 08:09 PM
check the harness that goes into the trans on the pass side. there is a small metal shield that covers it. once removed you will see the harness. it uses a plug "adapter" that has orings on it. they were redesigned because of this problem. it costs $7-$10 at the dealer. very common problem.
talkboxier 09-03-2012 03:30 AM
@84foxgt
I am ordered the the bushing with the new o-rings already, but I live in hawaii. I don't think I can wait much longer for it so I am gonna head to my nearest dealership and see if they have any.
@Piepenbrok420
that sounds like an awesome idea!!! :)
thanks guys, gonna try those and and post my results.
The time now is 06:09 AM.
