Volant Cold Air Intake vs Modified Stock Intake box - JeepForum.com
post #1 of 14 Old 07-31-2013, 11:27 AM Thread Starter
ChanWK
2005 WK
Hey
So I was going to purchase a volant cold air intake but my friend suggested otherwise he said he could drill 2" into the back of my OEM intake box to allow more cold air in. He's done it before and said that no water will get into it and it will increase the flow of cold air in. Just wanted to get an opinion if its worth getting the volant or if I should just drill into my stock intake box.
Thanks
ChanWK is offline
post #2 of 14 Old 07-31-2013, 01:44 PM
ca07wk
2007 WK
There is a big size difference between a 4" volant filter and tubing and the stock filter and tubing. What we used to do with the C5 vettes is remove the air box and zip tie the filter to the lid, I guess that similar to drilling a huge hole in the side.
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #3 of 14 Old 07-31-2013, 04:55 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
You will still have the baffle box which kills the air flow.
Omelet is offline
post #4 of 14 Old 07-31-2013, 07:13 PM Thread Starter
ChanWK
2005 WK
So best bet is to go with the Volant
ChanWK is offline
post #5 of 14 Old 07-31-2013, 07:28 PM
ca07wk
2007 WK
I installed the Volant on my 3.7 and I'm glad I didn't go with something else. I sell the Volant for $340 shipped
ca07wk is offline
post #6 of 14 Old 07-31-2013, 07:52 PM
WieSeL
Can you put an aftermarket tube on a stock air box?
WieSeL is offline
post #7 of 14 Old 07-31-2013, 08:03 PM
ca07wk
2007 WK
you can get either the Airaid, or Volant intake kit, which just comes with different pieces of intake piping and a filter.
ca07wk is offline
post #8 of 14 Old 07-31-2013, 08:54 PM
WieSeL
Wanna stick with stock air box and filter. A lot of dust at the wheeling spots out here and k&n's and paper filters don't do well with dust
WieSeL is offline
post #9 of 14 Old 07-31-2013, 09:08 PM
ca07wk
2007 WK
you can get the intake tube kits without the filter as well
http://www.airaid.com/U-Build-It_intake_systems.aspx
http://www.autoanything.com/air-inta...A7222A0A0.aspx
ca07wk is offline
post #10 of 14 Old 07-31-2013, 09:21 PM
WieSeL
Originally Posted by ca07wk View Post
Awesome thanks
WieSeL is offline
post #11 of 14 Old 08-02-2013, 01:09 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
I run an AFE dry filter with a prefilter wrap inside of my Volant and it works great with dusty trails (the only kind we have in SoCal ) . Much better than any OEM drop in filter will!
Omelet is offline
post #12 of 14 Old 08-02-2013, 07:37 AM
johngreen1234
2010 WK
+1 on the AFE dry filter and a pre-filter. That flimsy prefilter sheds dust so well that I'm always checking the tube joints to make sure air's going through.
johngreen1234 is offline
post #13 of 14 Old 08-02-2013, 08:03 AM Thread Starter
ChanWK
2005 WK
Sounds like I should invest in a volant
ChanWK is offline
post #14 of 14 Old 08-02-2013, 08:33 AM
WieSeL
Yeah that would be a must if I went with aftermarket paper filter. I used to run one on my dirt bike but the k&n was perfect for the sand
WieSeL is offline
