"Viper" throttle body for 3.7L - JeepForum.com
post #1 of 75 Old 03-12-2013, 11:13 AM Thread Starter
ca07wk
2007 WK
I've been doing some research for a buddy with the 3.8L JK, and I've seen alot of people adding, what they call a Viper throttle body, which is in fact just the 4.7L throttle body. The opening is 3" compared to our 2.5". Everywhere I looked the 3.7L and the 3.8L throttle bodies were grouped together, so I sent an email to MoparSuperCenter asking if they could find out if the 2 throttle bodies were similar with the same bolt pattern. They confirmed that the bolt pattern between the 3.7L, 3.8L, and "Viper" throttle bodies were all the same and that it would bolt up and plug in with no connector splicing.
I'd really like to see this swap on a 3.7L WK, and I would happily be the first guinea pig, I just dont have the funds, I will however start stashing money away, and looking through junkyards for one.
Through MoparSuperCenter the part# is 53032837AB cost $147.06
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #2 of 75 Old 03-12-2013, 11:47 AM
JordanD07
2007 WK
I think the 05-06 weren't drive by wire so be careful not to use an 05-06 one
'07 3.7 4x4 QT1 ll Red WK Club #27 ll OME ll Monroe LL ll Rusty's ll ProComp ll BFG ll 4xGuard ll S4XC ll VLEDS ll Infinity ll Thrush ll Riddler ll 6K HID
JordanD07 is online now
post #3 of 75 Old 03-12-2013, 12:03 PM Thread Starter
ca07wk
2007 WK
you are correct, the drive by wire TB is a mid 2007 change, the part number and price are for the drive by wire TB
ca07wk is offline
post #4 of 75 Old 03-12-2013, 12:13 PM
DeChache
2003 WJ
If it wasn't so cold out or I had a garage. I would try it. Keep thinking of getting a fastman for my 3.7 this is cheaper and if it has the same effect.
Though this will require an aftermarket pipe for the air box wont it.
DeChache is offline
post #5 of 75 Old 03-12-2013, 12:30 PM Thread Starter
ca07wk
2007 WK
The JK guys are using a 3-3 coupler, but they dont have the resonator box like we do. Im going to say a full aftermarket intake, like Injen, will probably be required, unless the 3-3 coupler will fit over the outlet of the resonator box. Ive read that a few JK guys with stock intakes were getting DTC codes, while the guys with aftermarket intakes were not.
ca07wk is offline
post #6 of 75 Old 03-16-2013, 10:06 PM
Piepenbrok420
Im gonna do this, will post pics when I get it.
Built Not Bought. 2013 JK trailrig. Instagram: @chrispiepenbrok
Piepenbrok420 is offline
post #7 of 75 Old 07-18-2013, 07:05 PM Thread Starter
ca07wk
2007 WK
Had a 4.7L throttle body sitting at my door today.
4.7L on left, stock on right.
Stock is roughly 2 1/2"
4.7L is roughly 3"
Initial road test is positive, smoother, quicker throttle response. Its comic con time here in San Diego so highway testing isn't going to happen this week.
ca07wk is offline
post #8 of 75 Old 07-19-2013, 12:56 AM
Piepenbrok420
4.7L is roughly 3"
**** yeah man, this is my next mod. Where did you order it from?
post #9 of 75 Old 07-19-2013, 01:15 AM Thread Starter
ca07wk
2007 WK
Off eBay.
ca07wk is offline
post #10 of 75 Old 07-19-2013, 01:19 AM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Nice, looks like a simple and effective upgrade! I have been told that the 3.7 is simply a 4.7 with 2 less cylinders, so I,m not surprised that parts between them are interchangeable.
Omelet is offline
post #11 of 75 Old 07-20-2013, 08:26 PM
ZJeepn08
2007 WK
How much larger, if at all, is the throttle body compared to the intake manifold?
And also, I've seen The Fastman selling these TB's taper bored for $265. Might be worth it to some.
ZJeepn08 is offline
post #12 of 75 Old 07-20-2013, 09:49 PM Thread Starter
ca07wk
2007 WK
I didn't mic the intake manifold but I can when the last piece of my intake gets here.
ca07wk is offline
post #13 of 75 Old 07-22-2013, 09:24 PM
Ted15
2010 KK Liberty
Nice
2010 KK Sport, Detoures Knucklebone & backbone, smittybilt XRC 10, rigid led lights, R/L sliders & rack, cb, EMT2, R/K 15x7, OME, JBA, mopar skids & hitch, headlight covers, 4.10's and TruTracs
Ted15 is offline
post #14 of 75 Old 07-23-2013, 08:53 AM
Piepenbrok420
The 3.7 and 4.7 intake manifold opening are both 3", the 3.7 throttle body is smaller.
post #15 of 75 Old 07-23-2013, 12:39 PM
huntb
2008 KK Liberty
Did you need an adapter to fit your intake?
huntb is offline
