| Moto Alliance Viper Elite 8,000lb Winch Giveaway! |
| Jeep Registry | Register | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
#1 | ||
Veggie Oil or Biodiesel Conversion for WK CRD
'04 WJ 4.7HO RE 2" BB 245/70/17 Revos |
#2 | |
the dpf may also not last as long on SVO and WVO |
#3 |
I run B100 in my 08 GC. I've had no issues so far. I actually think it runs better. I drive up to DC for soccer games (6 hour round trip). When I drove on 100% dino I barely made it back home and had to immediately go to the gas station the next morning for fear of running the tank dry. The last three times I've gone up on B100 I've made it back with a 1/4 tank left.
On the biodiesel.infopop forum I've read that NOx is actually reduced as compared with dino when burning bio made from WVO, which is what I use. Particulate matter is also reduced. I assume the regen cycle for the DPF uses the post combustion injection that has caused some concern here and elsewhere. Cylinder wetting and oil additive leaching seems to be the issue but has there been any real proof that it's a problem? I'm going to have my oil analyzed when I change it next to see. I imagine an increase in oil change frequency will be the fix. The fuel lines are bio compatible as the engine is rated for B5. Burning bio will not void your warranty due to the Magnuson-Moss Warranty Act of 1975. An auto maker cannot, by law, refuse to honor a warranty if their product has a problem not directly caused by burning bio. If you burn dirty bio and it causes a problem then the auto maker can refuse to honor the warranty. But that goes for dirty dino diesel too. If your favorite fueling station sells you bad diesel and it causes a problem then you're out of luck. Last edited by Section106; 05-23-2008 at 01:40 PM. |
#4 |
Section,
How many miles have you put on your WK while its been burning B100? I burn B100 in my RAM during the warmer months and its great. I’ve been really toying with the idea of grabbing a CRD WK for some time. This is really awesome news to hear first hand from some one having a CRD and running B100 in it. |
#5 |
jeep_on,
I've put about 2k on B100, 1k on B85, and 500 on B50. My Jeep was delivered in Oct of last year and as we came out of the winter I started to splash mix the different ratios in the fuel tank. I too was trepidatious about running B100. I'm glad I took the plunge. Diesel here in Hampton is now $4.65/gallon. I make it for around $1.20/gallon. |
#6 |
Very cool. I make my fuel also, but ours is around $2 per-gallon, maybe a little less. Only b/c of the high cost of methanol here around here. We buy it by the 55g drum, but have to drive all the way to Phoenix to get it (320mi round trip). I’ve been running it in all of my diesels are years now. The only exception is our box truck. Need to show fuel records and taxes paid incase DOT dose an audit. I’ve been toying with the idea of keeping track of gallons burned and paying the road tax on that, but just haven’t got around to getting the paperwork in order to do so. #2 Diesel is around $4.70 here.
#7 |
Diesel here in NW Washington State hit $5.15 a gallon today! Whoo hoo. Someone's getting rich. Oh wait, it's not me.
#8 | |
I've tried to fiqure out how to pay Virginia road tax to no avail. There are forms if you run a fleet but there is nothing for the homebrewer. I'm not complaining mind you. ![]() |
#9 |
Wow, 97% is really awesome in methanol recovery. I’ve been thinking of doing it for some time now, just haven’t got around to it yet. I’d save a lot of money if I did, even if I got 50% back. Are you simplify heating the glycerin up than re-condensing the methanol that vaporized in the heating process?
#10 | |
The column comes with water channels in the head and that keeps the head temp at 65C, methanol's boiling point. When the head temp starts to rise I turn on the hose and water moves through the head to the condensing column. I usually get back 3 gallons of methanol at 97-99% purity for every 15 gallons of raw glycerine. I've processed 2 batches of BD with the recovered methanol and both have passed the 3/27 test. One thing to note, it takes about 12 hours to get back 3 gallons. It's a long process! |
#11 | |
I had planned to go through another analysis before making the switch to B20 (running B5 now), but given your experience may switch sooner. In nay case, I'll continue to have my oil analyzed every 1000 miles or so to determine when I should change it. I'll be posting results after I have a few analyses back. |
#12 |
#13 | |
My second sample is on its way to Blackstone. Let them know you are running Bio Diesel and the vehicle you have. They collect stats on an engine by engine basis. PM me and I'll give you my Blackstone customer/vehicle info. It would be good for them to know we are interested in the same type of info. |
#14 |
Do you have to do anything to run the b100 diesel?
#15 |
You don't need to do any modifications to run on Biodiesel. Biodiesel can start to jell at cold temperatures so I use lower percentages in the winter.
I've got about 9,000 miles on my 2008 with about 1/2 of that (couldn't find any near I-5 up and down Cali.) running on anything from B50 to B99 depending on the weather. My mileage is a little better with B50 than straight dino juice or B100 and the exhaust actually smells good. Check out some of the facts from my supplier at: http://www.sqbiofuels.com/faq_diesel.html |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| An interesting read on the effect of biodiesel on the CRD | suzieque | WK & XK Technical Forum | 5 | 03-27-2009 10:53 PM |
| Who's Using Biodiesel | magellan | WK & XK Technical Forum | 36 | 11-12-2008 10:33 PM |
| 3.1TD fuel injection pump/ veggie svo | colinc57 | ZJ & WJ Technical Forum | 7 | 05-20-2008 02:29 PM |
| 249 to 242 conversion | cet2kill | ZJ & WJ Technical Forum | 3 | 07-31-2007 12:40 AM |
| Tie Rod Conversion | nex2nutin | ZJ & WJ Technical Forum | 1 | 08-15-2006 06:33 PM |
The time now is 06:03 PM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
