Valve stem broke. Mandatory to replace TPMS sensor? - Page 2 - JeepForum.com
post #16 of 66 Old 01-05-2012, 10:08 AM
BobbyB_WK08
2008 WK
I just had tires put on they also broke one of my stems. $38 from NAPA
BobbyB_WK08 is offline
post #17 of 66 Old 01-05-2012, 11:50 AM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Originally Posted by terrasmak View Post
BTW for everyone the rebuild kit cost is around $2 , it DOES NOT have to be done everytime they change tires, and should cost pennies to install when you are having tires installed.
Who sells 'em for $2?
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | Provent MBRP XP Exhaust | New Intake Tube & Seal + EHM | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
post #18 of 66 Old 01-05-2012, 01:58 PM
Rubes
Originally Posted by Mickey63 View Post
check your spare (if you've got one)
Spare is a space saver. I haven't checked, but does it have a TPMS?
Rubes is offline
post #19 of 66 Old 01-05-2012, 02:11 PM
oldmanscherokee
1992 XJ Cherokee
If they are the all metal stems with a nut on the outside you will have to get a new one, they are one piece. If they are the new style ones with a rubber valve stem the stems and the sensor can be bought seperately. Some cars have them in the spare tire as well but I'm pretty sure the jeeps don't. Even if it did and you moved it from the spare to fix that one the light would still be on since spares that have sensors are monitored as well. $112 is an average price, they vary from $45 to up to $200 and over for some cars. Do not band the sensor in the rim, sensors that are meant to be banded are banded style from the factory, If you're going to be cheap you shouldn't have optioned the system in the first place. As far as being illegal, it will be soon at inspection time in some states when they become standard from the factory on every vehicle. Along the lines of abs lights, even though you still have normal brakes if the abs light is on most states will fail you. Wash your wheels when you wash the truck and absolutely DO NOT use metal style valve caps and you will most likely never have issues with them again.
And complaining about removal/mount/balance on a tire repair is as stupid as complining about the disposal charge for "hazardous waste" from an oil change. Do it yourself if you don't want to pay for it...............
full time tech for chevy, part time trail rider
95 Ford Lightning (sold), 09 Caddy CTS-V, 04 Buell Firebolt XB12R w/true flame paint, 00 harley XL chopped, 81 Trans Am, 85 K5 Jimmy 4 inch w/35s, 92 cherokee
10,000 original miles
4.5 inch RC lift
32 11.5 bfg muds
oldmanscherokee is offline
post #20 of 66 Old 01-05-2012, 05:49 PM
Mickey63
2006 WK
My spare is full size and has TPMS, can't hurt to check....
Mickey63 is offline
post #21 of 66 Old 01-09-2012, 08:23 AM
Rubes
When I got home that day, I took it out for a ride (my other Jeep is a TJ). TPMS warning off! I guess I had to take it out farther than my driveway
Rubes is offline
post #22 of 66 Old 01-09-2012, 02:05 PM
terrasmak
2007 WK
Originally Posted by oldmanscherokee View Post
Do not band the sensor in the rim, sensors that are meant to be banded are banded style from the factory, If you're going to be cheap you shouldn't have optioned the system in the first place. ..
What is cheap about putting the sensor in a location where it still works and does not risk getting destroyed while offroading.
The thing that actually started the banding was people who wanted to keep their sensors when running high dollar 2 and 3 piece wheels on sports cars.
terrasmak is offline
post #23 of 66 Old 01-12-2012, 06:37 AM
relgawly
2010 WK
I've got a 2010 WK, with the basic TPMS, it has the aluminum valve stems, one just broke. Now the dealer wants over 100 dollars to replace it?!?!?! My car is no longer under warranty since i have like 44k on it. I've been reading the thread and looking at the rebuild kits. So are the rebuild kits an option for the aluminum valve stem model? Is it possible to buy the new style ones (separate sensor and rubber stem) to replace the old one? No point in buying something that has a problem that we all know.
relgawly is offline
post #24 of 66 Old 01-12-2012, 07:48 AM
GrilledJeep
2005 WK
I took mine off, all of them.
they were freezing anyways and shattering.
The light is on, but I know my tires are good.
Rubber stems make my life in the cold easier
GrilledJeep is offline
post #25 of 66 Old 01-12-2012, 09:35 AM
relgawly
2010 WK
Well it looks like the new model is a rubber stem, I want to know if this model is compatible with my system. If you search for this model number 56029481AB you will find an example.
relgawly is offline
post #26 of 66 Old 01-12-2012, 09:43 AM
tjkj2002
2002 KJ Liberty
Temp spares do not have TPMS,only a full size spare will and then it's a option(package) to have the 5 tire TPMS system.
Ford was really the only ones that ever had the banded TPMS sensors and they have scraped that idea long ago as it was a bad idea.
No you can not switch to the new style sensors due to them operating at a different frequency then what your system requires.Those rebuild kits just replace the sealing parts and not the sensor or valve stem.
tjkj2002 is offline
post #27 of 66 Old 01-12-2012, 02:37 PM
RIDER6
2008 WK
This is the only tpms thread I could find so sorry if I vear off course alil....a few days ago I played in the snow.....needless to say my tpms came on yesterday and I thought it was from the cold and now my tire is kinda flatish....I threw air in it and am monitoring it to see if it goes back down....now my question is does the light stay on or does it turn off automaticly or do I gotta go to the dealler to get it turned off....or is there a cheat to turn it off like the oil change warning???? All input will help and I can't research too much cause I'm at work...thanks guys!
Blue WK Club Member #TwO OH...
"I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it."
RIDER6 is offline
post #28 of 66 Old 01-12-2012, 03:12 PM
Coasty161
IIRC it should go off after a couple of revolutions of the tire. As long as that was the issue
Silver WK Club Member #21
2007 Jeep Compass (sold)
2008 Jeep Grand Cherokee (sold)
2008 Jeep Wrangler unlimited 4d (current)
2012 Dodge Durango (current)
Coasty161 is offline
post #29 of 66 Old 01-12-2012, 03:45 PM
sk1er18
2007 XK Commander
Depending on model year you actually can since Chrysler has superseded the old sensors with the new style. I just did this a few weeks ago.
In terms of the XK the part numbers are as follows (XK model year - old PN - new PN):
2006 - 56053030AB - 68078861AA
2007 - 56053036AA - 56029479AB
2008 - 56029359AA - 56029481AB
-Matt
sk1er18 is offline
post #30 of 66 Old 01-12-2012, 04:24 PM
RIDER6
2008 WK
Were all good....thanks for the input jeep brotheren.....picked up a screw from a snow bank....thanks tho.
RIDER6 is offline
$220 to replace a valve stem?! impulse001 WK Grand Cherokee & XK Commander Forum 10 09-18-2010 05:22 PM
Valve Stem Core... Broke in my hand Indian WK Grand Cherokee & XK Commander Forum 3 04-26-2010 08:57 AM
Broke a TPMS sensor - how to bypass or disconnect? Veccster WK Grand Cherokee & XK Commander Forum 3 01-19-2010 01:32 PM
Valve Stem for TPMS sender JKM WK Grand Cherokee & XK Commander Forum 1 02-01-2009 06:18 AM
Broken TPMS Valve Stem RyanZJ WK Grand Cherokee & XK Commander Forum 6 12-11-2008 02:40 PM
