Valpacer's WH Build Thread (War Machine) - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Valpacer's WH Build Thread (War Machine)
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 11-02-2012, 03:44 PM   #91
Valpacer
2007 WK
Originally Posted by BonesWK View Post
Dave, you ever pick up those Black Rock Yumas?
No, they couldn't get in any in the size and offset. Shelved those plans for now.
Quadratec werent gettting their next shipment till after Christmas.
Dave
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries - [URL="http://www.jeepforum.com/forum/f67/valpacers-wh-build-thread-war-machine-1376368/"]Build Thread[/URL] - [URL="http://www.youtube.com/user/valpacer?feature=mhee#p/a"][U]YouTube Vids[/U][/URL]
Valpacer is offline   Reply With Quote Quick reply to this message
Unread 11-02-2012, 03:49 PM   #92
Valpacer
2007 WK
Originally Posted by JeepinShep View Post
Man Dave, those UCAs are gonna be awesome.
When are you sending them to me?
Haha, Ill do one better. The Currie Johnny joints are off the shelf, just need 3mm machined off each side of the mounting boss, and the other end is a factory bush. Ill give you the tube measurement and then its easy to get a shop to make it up
Unread 11-03-2012, 08:41 AM   #93
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Those looks nice Dave! I still need to get a set of upper and lowers made. So will the joint have enough room to flex in the mount after they are shaved down?
See How It Was Made
Omelet is offline   Reply With Quote Quick reply to this message
Unread 11-03-2012, 09:17 AM   #94
Valpacer
2007 WK
Yep, ill get some photos tomorrow when i put them on. IT will get rid of some of the bind in the rear. Should do the same with the lowers, but i will hold off till the Long arms go in. This was more for correcting the pinion angle.
Unread 11-03-2012, 10:21 AM   #95
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Awesome man! I have spect out some lowers and know what I will use, but haven't done the uppers yet so this is good. I would really love to do the long arm and cantilever idea I have been wanting to try, but for now some new arms with flex joints is all I can do. We will see what I can afford and have time for once I come back from deployment. So is your plan to remover the OEM fuel tank and do a fuel cell under the rear (spare tire location)? What's the capacity you think you can squeeze in there? I have seen some guys fit a 10 gal. aux tank down there without limiting clearance, but it would need to be at least twice that size. I guess since the War Matchine is so tall loosing a few inches under the rear wouldn't be the end of the world
See How It Was Made
Unread 11-03-2012, 03:27 PM   #96
Valpacer
2007 WK
Yep, factory fuel tank will be landfill.
LRA tanks down here do a long range 128l tank that fits where the spare was. It only sits as low as the factory subframe rails. So no loss of clearance at al Even with the factory sender and pump unit installed, and an extra thickness lower bash plate it will have over 100l of capacity. THey are going to make a custom one to suit based on their current design. Works out to around 26gal i think!
Actuall ride height will drop from this when the long arms go on as well, but flex will be epic. Hopefully!
Unread 11-03-2012, 08:54 PM   #97
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Sounds awesome!!! You should be able to tuck the tummy for a better break over too!
See How It Was Made
Unread 11-03-2012, 09:01 PM   #98
Valpacer
2007 WK
hell Yeah! We have a new trans crossmember in development as well, 1/4" high as opposed to the 2" one that is there now. With integrated skid to mate to the SL skid as well.
Unread 11-04-2012, 01:15 PM   #99
Valpacer
2007 WK
1.25" JJ, 370mm total length of the arm (without JJ), 46mm OD tube. You could go the next size down JJ as well I reckon, it would still be large enough.
Unread 11-04-2012, 02:53 PM   #100
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Thanks for the info! So how much longer than stock are you running them?
See How It Was Made
Unread 11-04-2012, 03:11 PM   #101
Valpacer
2007 WK
Dont know yet! Ran out of time, need to get the driveshaft out to get the fuel tank out to get the passenger arm off. Will have to be one night this week!
Unread 11-05-2012, 09:17 AM   #102
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
That's right! I want some better arms in there, but I'm not looking forward to the instal process.
See How It Was Made
Unread 11-18-2012, 04:03 PM   #103
Valpacer
2007 WK
Unread 11-18-2012, 05:11 PM   #104
SSF556
2008 WK
Awesome vids and pics....
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline   Reply With Quote Quick reply to this message
Unread 11-19-2012, 08:38 AM   #105
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Great post, Dave!
----> War Machine
I am not worthy..................
~Mike~
Build Thread WK
Other Build Thread XJ
September 2013/January 2015 COTM
JeepN4KC is online now   Reply With Quote Quick reply to this message
