Using other wheel dimensions with TPM-System - JeepForum.com
post #1 of 6 Old 11-27-2015, 03:04 PM Thread Starter
Manni
2006 WK
Hi Jeeper,
do you have experience on the use of the TPM with larger wheel dimensions?
Since I started using 265/65R18 tires stopped working my TPM. Thank you for
your answers.
°lllll°
Have fun out there!
Manni
Grand Cherokee Overland WH · MY 2006 · 5.7L HEMI V8 · 345 cui · Prins VSI LPG · Remus Exhaust · 50 mm Track Spacers · 2" Trailmaster · 265/65R18 BFG AT
Manni is offline
post #2 of 6 Old 11-28-2015, 07:00 AM
airportdave
Either Flyin' or Jeepin'
airportdave's Avatar
2010 WK
Same thing for me when I put 17x8 Ultra Spline wheels on my GC- no spacers, but 35mm offset, so outer edge of wheel is almost 1" further out than stock. Good news is that while tire pressures don't update, there is no TPMS warning system light on.
2010 Grand Cherokee Limited Hemi Q-D II, OME MD, 265/70/17 Hankook ATM's, HemiFever Tune
airportdave is offline
post #3 of 6 Old 11-28-2015, 08:01 AM
Montreal300
The size of the wheel or the rubber has no effect on the TPMS system. Did you use the OEM TPMS sensors or get different ones? I've found that the aftermarket sensors don't always play nice with the system. The Dorman versions in particular are a pain.
Montreal300 is offline
post #4 of 6 Old 11-28-2015, 01:06 PM
atarijedi
2008 WK
I put Dorman direct replacements in mine, no issues at all. The TPMS light on the dash went out after about 15min of driving.
atarijedi is offline
post #5 of 6 Old 11-28-2015, 03:52 PM
Montreal300
Should have been more specific. The lower frequency 315mHz(?) seem to be the problem. The newer 433 mHz units seem to be better,
post #6 of 6 Old 11-28-2015, 04:19 PM
LouC
2007 WK
I have 245/70-17s that are about 1" taller than stock and with the OE sensors the TPMS works perfectly.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline
