Urgent Help Needed - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Urgent Help Needed
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSteinjager TJ tube doorsAttention to the TJ owners 1996-2006 NEW LED LIGHT OPTIONS
Unread Yesterday, 02:23 AM   #1
thecalkid
2005 WK
Location: San Jose / Hollister / Sacramento / Palo Alto, California
Urgent Help Needed
Does any one know what these harness connectors are called? A part number maybe? I broke the red clip thing when trying to remove the harness from the transmission line pressure sensor to install a sonnax. Now I can not remove the harness at all. I've been trying everything to work whats left of the red clip out, but I may just have to break the harness and wire a new one in.
thecalkid is offline   Reply With Quote
Unread Yesterday, 08:04 AM   #2
agitator19
2007 WK
Just cut the wires and install two butt connectors. How many more times are you going to disconnect them? Not the best, but will get you back on the road!
agitator19 is offline   Reply With Quote
Unread Yesterday, 02:06 PM   #3
thecalkid
2005 WK
Well I figured it out. I didn't want to cut the wires because I like having the option of going back to stock after getting a superchips tuner. I ended up trimming back some of the clip and prying it out gently. Then I fashioned a new clip and secured it with zipties and heat shrink tubing for good measure.
Unread Yesterday, 02:27 PM   #4
tom19511
2006 WK
Good to hear!!
Tom19511
tchristopher1@wowway.com
2006 Grand Cherokee Laredo 3.7
2007 Liberty Sport 3.7
tom19511 is offline   Reply With Quote
