Upper radiator hose full of air - JeepForum.com
post #1 of 10 Old 08-11-2013, 11:36 AM Thread Starter
zeds_dead
2005 WK
I took off my upper radiator hose today planning on replacing the tstat, and when I put it back on, turned on the engine, it's just full of air. Is there any way to let the air out?
Everyday, something new you want to do. Disease of Jeeps.
zeds_dead is offline
post #2 of 10 Old 08-11-2013, 03:40 PM
fishinbama
2007 WK
Generally you should fill the coolant to the top by removing the radiator cap. Make sure the engine isn't hot before filling. Make sure you have some coolant in the coolant reservoir and it will finish sorting itself out.
2007 limited crd 2wd, 3.07 ratio, GDE eco tune, dpf delete, tnadanzig resonator delete
fishinbama is offline
post #3 of 10 Old 08-11-2013, 04:21 PM
Walt
2008 WK
If the air isn't purging, that's a symptom. I suspect the radiator cap could be going bad. Should suck coolant (from the overflow tank) back in to the main system at cooldown via vacuum relief. I would start by replacing the radiator cap (Stant or good quality equivalent).
When you refill the coolant system, try to park pointing slightly uphill. Refill the radiator and let it perk down. Squeeze the top hose until the air bubbles appear in the filler neck and it will refill the upper hose somewhat. Repeat several times until no more bubbles appear. Top up the radiator and overflow tank. Finally, make sure the overflow tank is at the high mark with coolant solution.
Run engine until t-stat opens and you should see more bubbles appear at the fill neck. Refill again to take up the air space. There is a bleed plug over the t-stat housing, but I did not have to use it when I changed coolant. All of the air came out with the above approach.
Check your coolant overflow tank several times over the next week and refill as necessary (as the air burps out of the coolant system).
BTW: Think the '05's use HOAT coolant like the '08's. MOPAR recommends not mixing anti-freeze types.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #4 of 10 Old 08-11-2013, 05:53 PM
Tango.
2008 WK
it will work its way out ... you can drive it around until it gets a little warm and then add fluid when it cools off.
Tango. is offline
post #5 of 10 Old 08-11-2013, 08:44 PM
WieSeL
Unscrew the bleeder screw a little and let the air out and then close it back up. Run it during this process and not when hot or pressurized
WieSeL is offline
post #6 of 10 Old 08-11-2013, 11:44 PM
colinzj
2006 WK
The 3.7 and 4.7 have a bleeder plug at the upper hose inlet. With a stone cold engine, completely remove it (you'll need an allen key), fill the system until fluid starts coming out of that hole, replace the plug (again with the allen key), and then fill the overflow tank until it's full. Don't touch the bleeder plug again.
Start up the Jeep and let it run with the heater on full heat. After you reach the middle of the temp gauge, shut down, let the vehicle cool off, and add whatever makeup fluid you need. Repeat this part of the process two more times. Have a beer. Air should be gone and fluid level should be stable.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #7 of 10 Old 08-12-2013, 12:18 PM
bigpav7
anyone know where the bleed screw is on the hemi?
bigpav7 is offline
post #8 of 10 Old 08-12-2013, 06:44 PM
WieSeL
By the upper hose underneath the intake tube area
WieSeL is offline
post #9 of 10 Old 08-13-2013, 11:24 AM
bigpav7
Is it the one you need an allen key to open?
bigpav7 is offline
post #10 of 10 Old 08-13-2013, 01:28 PM
WieSeL
Yes
WieSeL is offline
